Author: Subject: brake hoses
RICK1
posted on 28/1/05 at 09:57 PM Reply With Quote
brake hoses
Could anyone tell me the lengths of the brake hoses+size of pipe,what and how many fittings i would need 4 a luego velocity xt with sierra calipers allround.Would prefer 2 make my own hoses.?
tks
posted on 28/1/05 at 11:23 PM Reply With Quote
well
pall
just start from the brake cilinders...
depending on your configuration...
but what you need is minimal 1 three way piece
1 4 way piece (for the brake switch)
then you should fet the pieces each one line (thats 2)
and the brake calipers you also need to fit
thats 4
soow minimum its 6 brake lines to make
in case you do it with one brake cilinder then you need 7 lines and one 3 way piece extra..
you also need flexible hosings
Luego suplly them with you. Goodridge..
TKS
