New Topic New Reply
Author: Subject: Zetec OBD2 Port
pekwah1
posted on 2/10/20 at 07:50 PM Reply With Quote
Zetec OBD2 Port
Hi Guys,
Just went to wire up my OBD2 in my Striker with a Blacktop Zetec on standard ECU, but the wires on the OEM guide don't seem to marry up to what i have.
As you can see from the picture, the wires on my car seem to be different:
Does anyone have any idea which wires i should be using?
Thanks,
[Edited on 2/10/20 by pekwah1]
perksy
posted on 2/10/20 at 08:24 PM Reply With Quote
This is one for Bigwasa, He will hopefully be along shortly and advise
big_wasa
posted on 3/10/20 at 01:12 PM Reply With Quote
Don't worry about the colours just the pin numbers.
I guess you have a random obd2 from another car. Just pull the green slide from the back and you can move, remove or add pins.
big_wasa
posted on 3/10/20 at 01:13 PM Reply With Quote
Mondeo or Focus ecu ?
pekwah1
posted on 3/10/20 at 02:29 PM Reply With Quote
Hi thanks, yeh guess I’ll need to pull the ECU out to trace the pins.
It’s from a year 2000 Mondeo, maybe an OWL5
big_wasa
posted on 3/10/20 at 02:36 PM Reply With Quote
The picture, is that of the obd2 plug ?
The colours should be as listed for the owl5 but I have seen all sorts.
You only need three pins from the ecu two earths and a switched live.
pekwah1
posted on 3/10/20 at 03:04 PM Reply With Quote
The pictures from the ECU plug, I had to get a new OBD2 socket which I’ve wired with the colours you suggest on the OEM guide.
Again think I’ll just have to take the ECU out and trace the wires
New Topic New Reply
