<<  1    2  >>
Author: Subject: Garage metal clad sockets recommendation please
pigeondave
posted on 5/11/20 at 05:52 PM Reply With Quote
Hi all,
I'm looking to get more power to the garage and was wondering about the different prices of double sockets.
I have my eye on 5 of these
https://www.tlc-direct.co.uk/Products/CM3356.html
But are they cheap for a reason, MK metal clad are £13 a pop, its quite a jump.
The feed to the garage is plenty man enough for 5 doubles, as its coming out the 3phase box in the bakery.
Just looking for a fair priced metal clad socket recommendation.
posted on 5/11/20 at 05:56 PM Reply With Quote
Do they have to be metal-clad? You're paying a premium for that decorative feature.
Ordinary twin sockets from reputable makers are as cheap as chips.
joneh
posted on 5/11/20 at 06:21 PM Reply With Quote
I've had stuff from TLC, it's been good in the past. Say British made with 25 year guarantee. Not sure about the British made part , but 25 years sounds like they're built to last.
posted on 5/11/20 at 07:16 PM Reply With Quote
Good point - I fitted a load of MK domestic double sockets in my garage. They're robust enough and more than up to the job. Metal clad ones seem OTT for a garage really. We even have a couple of outdoor power sockets and they're certainly not metal clad.
Myke 2463
posted on 5/11/20 at 07:37 PM Reply With Quote
Screwfix £4.99 13A 2-Gang SP Switched Metal Clad Socket with White Inserts (69127)
Be Lucky Mike.
cliftyhanger
posted on 5/11/20 at 08:06 PM Reply With Quote
I would use Double Pole (DP) switched sockets. Many are SP.
DP disconnects live and neutral, which is preferable. But not essential.
If you chose to use plastic surface boxes, avoid the cheap crappy ones. They crack/break just for a laugh, or the brass screw inserts pull out. You can (or could) get PVC ones which are much more durable.
Charlie_Zetec
posted on 6/11/20 at 12:01 AM Reply With Quote
^ These are what I've used in my garage, complete with the metal trunking along the ceiling, and plastic conduit to the boxes (new build garage/extension, so had to comply with building regs).
Wouldn't bother with plastic boxes in the workplace, as they tend to break with any sort of knock/impact.
I love the MK bits, and have used their faceplates in the house when I re-wired, but couldn't justify the extra expense on their metal boxes when the above were significant cheaper. I have also found that the MK faceplates are specifically designed for their surface-mount backboxes, so mixing & matching manufacturers when assembling doesn't always look pretty or fit well.
posted on 6/11/20 at 08:20 AM Reply With Quote
Might be a good idea to fit one or two with USB charging points built in?
pigeondave
posted on 6/11/20 at 08:29 AM Reply With Quote
They're a nice idea but pricey, but could prove useful. I'll have another think.
I saw these but wondered about how robust they were. Hence the question on the thread. Thanks for the info.
Metal clad just looks right in a garage though
posted on 6/11/20 at 08:35 AM Reply With Quote
They're always more expensive and most households seem to have an abundance of USB chargers (we do). I pilfered a couple for the garage and just made sure I fitted sockets in the right places on the wall. Left the USB chargers plugged in with cables handy for charging phones the odd cycle light and even a tablet if needed. Every time you replace your mobile phone you still have the old charger and USB charger cable - use them.
I should add that my garage is integral to my house and my household consumer unit is also in the garage. This made installing the wiring easier and the garage had it's own circuit. I also installed with the wiring in surface mounted flat conduit.
[Edited on 6/11/20 by nick205]
steve m
posted on 6/11/20 at 08:57 AM Reply With Quote
I dont know how any one can break a patrice box and socket plate, as i have never done so! nor seen it, and i worked for an electrician
My garage has normal white Mk sockets, and ive never had a problem with any of them, nor anywhere else in the house, and in the 34 years we have been in this house/garage ive rebuilt several Minis, a couple of motorbikes, and made a Locost from scratch, and never had an issue!
As for the Usb plates, we have a couple in the house, and in the garage, and ive never paid more than £9 each for them
Unless your garage is going to be a full on industrial workshop with 3 phase machinery, etc, metal boxs imho are a total waste of money
steve
gremlin1234
posted on 6/11/20 at 10:46 AM Reply With Quote
I dislike the built in usb sockets, since
a) typically they take a constant 2W load - even when not in use *
b) only dumb slow charging
c) have to replace the whole socket when the usb bit fails
* they tend to use a capacitive dropper psu, since they are small and cheep.
plugin chargers tend to use switch mode psu, which are more efficient, and allow for higher power (fast charging)
I say, just use a plugin charger
posted on 6/11/20 at 11:34 AM Reply With Quote
Valid points I'd say + as I mentioned above most households have a surplus of plugin USB chargers kicking about. Save the electric waste and landfill and use them instead. The plugin USB charger Samsung supplied with my current mobile will charge the phone in a couple of hours.
SteveWalker
posted on 6/11/20 at 12:18 PM Reply With Quote
Built-in chargers have the great advantage that they do not get taken off by your children to other rooms and leave you searching for them after they have gone to sleep!
Bigheppy
posted on 6/11/20 at 02:55 PM Reply With Quote
I got a bundle of metal MK sockets from a car boot. Think I paid £2 for 10. All have been found to be in perfect working order. I think many were hardly used. The only issue is that they are Gold
gremlin1234
posted on 6/11/20 at 03:00 PM Reply With Quote
but they may take the charging wire that plugged into it ;-(
pigeondave
posted on 6/11/20 at 03:08 PM Reply With Quote
The garage is at the (family) bakery and I'm the only one that goes in there really, so its not a massive issue.
Thanks all for chatting this one through, I'm going to go with the linked ones, they're reasonably priced for metal and I fancied metal.
I would ask should I get 3phase piped down there as I have two spare slots on the board in the bakery, but I don't want to start an argument amongst you all
Thanks again everyone
gremlin1234
posted on 7/11/20 at 12:00 AM Reply With Quote
Originally posted by pigeondavebut I don't want to start an argument amongst you all
nope, no arguments, just good honest discussion
cliftyhanger
posted on 7/11/20 at 06:46 AM Reply With Quote
You are local to me, I was at Denmays yesterday.....
Be careful about linking to the bakery. I suspect commercial electrical testing is quite fussy?
But 3 phase would be a lovely idea, plenty of quality kit out there that us single phase people can't buy, so tends to be very cheap. Lifts/compressors/welders even lathes/milling machines.
indykid
posted on 7/11/20 at 11:05 AM Reply With Quote
I now have a 3 phase lathe, 3 phase milling machine and 3 phase pedestal grinder all running off VFDs. I've also made a pottery wheel and that's 3 phase too.
Even if I had 3 phase out to the garage, I'd still want to run them on 3 phase to 3 phase VFDs as the speed control and braking makes the tools so much more usable.
Unless you need to run mega horsepower industrial kit, I don't see the value in running the cable and switch gear (but I do have metal clad sockets )
SteveWalker
posted on 7/11/20 at 11:35 AM Reply With Quote
But what are they going to plug them into? Anyway it's easy to buy leads in abundance from the pound shop and they can have as many as they like!
pigeondave
posted on 17/11/20 at 02:04 PM Reply With Quote
There seems to be a better alternative now according to this video (it's in the right place)
https://www.youtube.com/watch?v=HIsTK42o8g0&t=297s
Seems these new ones will do fast charging
https://www.hamilton-litestat.com/decorative-wiring-accessories/eurofix/usb-power-sockets-modules/
Wonder if they still have a parasitic draw?
gremlin1234
posted on 17/11/20 at 06:27 PM Reply With Quote
I watched that and its follow up video, they tested 4 together and it was a total for all 4, 1W, so better than the older ones.
but the 13A sockets still only do 5V usb
as I have said previously, I prefer a plug in charger that I can turn off or remove
[Edited on 17/11/20 by gremlin1234]
v8kid
posted on 18/11/20 at 02:18 PM Reply With Quote
Back to the sockets, you would have to be very silly not to use metal-clad. I'm an electrical engineer and I've seen umpteen cracked plastic sockets but to put it in perspective, never a directly connected fatality, although I've heard about them
Toolstation metal-clad are good I fitted them in my garage and in the kids garage as well.
Remember to make sure you have a metal-clad fuse board ( mandatory due to fire regs) with a min of 1 RCD protecting the sockets. New regs require RCD on lighting circuits as well.
When wiring to the sockets the wiring will have to be mechanically protected and for the sake of a few quid whats not to like about fitting plastic conduit where liable to damage?
Check the loop impedance, if its poor all the protection in the world is worse than useless, worse cos you think its safe when its not.
After all that doom and gloom if you can make a kit car this should easily be within your capabilities if you do your research.
Happy Sparks
Cheers!
You'd be surprised how quickly the sales people at B&Q try and assist you after ignoring you for the past 15 minutes when you try and start a chainsaw
SteveWalker
posted on 18/11/20 at 04:15 PM Reply With Quote
While conduit is good practice, there is no requirement for conduit or any mechanical protection for surface mounted T&E, unless the regulations have changed. Indeed, although RCDs are required for sockets or for cables buried less than 50mm into walls, I don't think they are needed for surface mounted cables - probably because there is no danger of someone accidentally knocking a nail into one or drilling through it.
In my own case, I have used both conduit and RCBO though and I do think it would be daft not to.
<<  1    2  >>
