Author: Subject: Capri Strut
ian.stewart
posted on 29/11/20 at 06:19 PM Reply With Quote
Capri Strut
OK, Have a dilemma and making plans for the future (not Nigel) thinking forward about the slow evolution of my car, and the very awkward front suspension, which has its geometry compromised once you try and lower it to where I want it, with a small amount of fabrication and using the original suspension pickup points, I may be able to use a shortened (very) capri strut, what I need to know are there any bottom ball joints that will fit in the strut taper and be able to bolt on to something, I know Austin Ambassador ones fit but are push in to a hole in the TCA, I want bolt on, so I can faff about with geometry and get what I want. any suggestions?
Something different, Very different..............
Rich J
posted on 29/11/20 at 09:19 PM Reply With Quote
Striker has cut down Escort legs and uses Sherpa right hand track rod ends for bottom ball joints - QH QR1774 and have 3/4UNF male threads
