Author: Subject: Sierra mk1 steering column covers
falcor75
posted on 21/1/21 at 07:25 AM Reply With Quote
I would be interested to buy the upper and lower covers for an early Sierra with the square hazard button.
Just found that I have a set of early steering column but late style covers which doesnt match up the mounting holes etc.
jps
posted on 21/1/21 at 09:06 AM Reply With Quote
Extremely rare I believe!
I recently watched a 'Late Brake Show' episode on Youtube, where the chap had made his own column cover for his Ford Escort - might be the best option? (This was the episode: https://www.youtube.com/watch?v=pQMcHITnoG8)
Johnmor
posted on 21/1/21 at 10:47 AM Reply With Quote
Hi
The column covers are now very hard to find at anything like a reasonable price, I spent 3 months looking and ended up buying a complete column with cracked and damaged covers , only wanted the plastics,
Some transit covers were similar as they use a similar hazard switch, also try looking for P100 column as this was Sierra based and used same switch.
I looked at fiesta type and although the hazard switch was the same the plastics were way out of shape for the Sierra column
Good luck
falcor75
posted on 22/1/21 at 06:54 AM Reply With Quote
Yes I may have to use my non matching set and create my own from aluminium.
posted on 22/1/21 at 07:26 AM Reply With Quote
Perhaps someone would be able to 3 d print one?
wowblaauw
I have a set; I'll dig out pictures later and U2 them to you.
Craig
"Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well preserved body, but rather to skid in sideways, chocolate in one hand, wine in the other, body thoroughly used up, totally worn out and screaming...
Damn, What a ride!!"
falcor75
posted on 22/1/21 at 08:28 AM Reply With Quote
I could 3D print it myself but taking the time to model it and then get a good enough surface finish + the brittleness of PLA then I think its easier to make a cover directly from aluminium if I cant find a used set.
posted on 22/1/21 at 11:20 AM Reply With Quote
I think that'd be my approach to make the parts from sheet Ally, formed to the right shapes. I did similar on my MK Indy to cover a gap between the Sierra top plastic and dashboard - I covered it with black vinyl before fixing it in place.
falcor75
posted on 22/1/21 at 05:57 PM Reply With Quote
Nice looking Indy
steve m
posted on 22/1/21 at 06:47 PM Reply With Quote
Its easy to make a cover, mine was a baked been tin , covered in vynal
Deckman001
posted on 22/1/21 at 07:25 PM Reply With Quote
But make sure you remove the battery terminals before you try and fit the baked bean tin, as I forgot to do that and blew fuses when the tin caught the key switch terminals
Jason
posted on 23/1/21 at 12:03 AM Reply With Quote
Nice looking Indy
