Author: Subject: Vibration when take off
timbo7
posted on 15/2/21 at 09:53 PM Reply With Quote
Westfield Hayabusa Gen 1. No reverse system - straight through prop.
When take off from junction getting a worsening vibration/rumble - at low speeds. No vibration when driving normally or accelerating. This only happens from a standing start. It is fairly noticeable now, but strangely only evident when accelerating from a junction/stand still.
Any ideas guys? Anyone came across this or similar before?
WESTFIELD HAYABUSA 1400 - SOLD
gremlin1234
posted on 15/2/21 at 11:38 PM Reply With Quote
on a standard engine setup the first thing would be to
check engine/gearbox mounts
but on a bec... it might be all solid mounts - still check them and the diff mounts too
Mr Whippy
posted on 16/2/21 at 07:53 AM Reply With Quote
Could be an unevenly worn clutch, I had this on the Fiesta. I replaced all the engine mounts but really it just needed a new clutch.
pmc_3
posted on 16/2/21 at 09:35 AM Reply With Quote
Check the propshaft bolts, from what I've read in the past they have a habit of working lose at the engine prop adapter.
adithorp
posted on 16/2/21 at 10:27 AM Reply With Quote
And the prop adapter nut/bolt.
http://jpsc.org.uk/forum/
