Author: Subject: Engine Temps
simon04
posted on 7/3/21 at 05:52 PM Reply With Quote
Engine Temps
Hi All
Ok so the question today is as follows.
Brand new crate engine 2.0l Zetec blacktop.
What would you all suggest the correct running temp is?
I have an inline water temp sensor from ETB feeding an ETB gauge which is about 6 inches from the thermostat feeding the top rad hose
I also have the normal ford Water Temp sensor in the thermostat housing feeding the ecu.
They are both giving different readings.
So question is what sort of temp does a normal zetec black top run at??
Thanks all
Simon
[Edited on 7/3/21 by simon04]
obfripper
posted on 7/3/21 at 06:22 PM Reply With Quote
The one in the top hose should fluctuate as the thermostat operates and could be as much as 20c different , the ecu one is prior to the thermostat so should peak a touch hotter and fluctuate less.
I normally see 90-94c in my ecu datalogs depending upon load etc, my gauge is connected to the second sensor on the thermostat housing - later engines have a blank fitting with no second sensor.
Dave
ian locostzx9rc2
posted on 7/3/21 at 06:57 PM Reply With Quote
90degs is were it should be if your running an electric fan it should come on around 95/96 degs
