Author: Subject: ZX10R sump chopped
roadrunner
posted on 20/3/21 at 03:21 PM Reply With Quote
ZX10R sump chopped
I've had my sump chopped as it was 50mm below my chassis.
Do I need to make up for the lost volume of oil or should I be ok.
Was wondering if there's such a thing as an expansion tank that can be connected to the sump.
If left as is, I guess just a more frequent oil change would suffice.
Regards
Brad
ReMan
posted on 20/3/21 at 11:37 PM Reply With Quote
If you've taken 50mm off thats a significant amount of oil guessing a litre or more at least?
I guess you could extend, that might help with the cooling capacity, depending on the engine etc, but for lubrication I'd agree that you change it more often.
Have you got it baffled as well?
Just thinking if theres not as much to pick up it could be interrupted on hard corners from surge
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
roadrunner
posted on 21/3/21 at 12:45 AM Reply With Quote
Thanks Reman
I filled the offcut with water then measured it.
I was surprised to see it was only 200ml. The engine takes 4 litres of oil. So not a significant loss.
I have a baffle plate to fit once I've sorted the new drain plug.
[Edited on 21/3/21 by roadrunner]
ReMan
posted on 21/3/21 at 09:21 AM Reply With Quote
That’s not too bad then. I pictured in my head a sump 200mm x 200mm x 50mm and that Works out at 2 litres!!
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
40inches
posted on 21/3/21 at 11:48 AM Reply With Quote
Not sure about the ZX10 but on the ZX9 the norm was to fill to just below the top of the sight glass.
I also fitted a baffle plate sandwiched between the sump and block.
roadrunner
posted on 21/3/21 at 06:55 PM Reply With Quote
I have a baffle plate to fit.
Going to see if I can use an oil extraction pump. Will save me fitting the sump plug.
roadrunner
posted on 25/3/21 at 08:42 AM Reply With Quote
Looked at using the oil extraction pump last night.
It was a tight squeeze, but managed to get the pipe passed the clutch basket and into the sump area.
I've measured the amount of material to remove from the oil pick up pipe and because it's plastic it will be a doddle to rework.
So close now to it's long awaited drive out.
roadrunner
posted on 26/3/21 at 08:38 PM Reply With Quote
CRAP.
I've cracked the corner of the sump.
Think it's down to the fact I'm using 2 gaskets with having the baffle plate in.
Had my fingers crossed it wouldn't leak, but
On the plus side , I've had my eye on a second hand billet sump.
Picking it up tomorrow from a fellow Indy owner.
roadrunner
posted on 31/3/21 at 12:55 PM Reply With Quote
Billet sump fitted. Look's a proper job
Booked in for MOT next Friday.
[Edited on 31/3/21 by roadrunner]
