Author: Subject: Exhaust silencer diameter Q
J666AYP
posted on 21/3/21 at 11:24 PM Reply With Quote
Hi all,
Just in the process of ordering the exhaust silencer and gubbins for finishing the exhaust system off. Just wondering if I would be better off with a 6" or 7" diameter silencer? (3" bore and 18" long).
Thanks,
J
ianhurley20
posted on 22/3/21 at 08:38 AM Reply With Quote
I simply went for the biggest straight through silencer I could fit - 24" x 7" 52mm bore - car sounded great, only got noisy when on full throttle but a lovely noise the rest of the time and 5db below legal limit at IVA
My build blog http://ianhaynes20.wordpress.com IVA passed 3/10/16
written off 23/9/18
Aug 2019 completed Tiger Avon with ST170 on TB's
Now restoring 1968 Ginetta G4
And - a series 1 Land Rover - don't ask why! - 03/21 - Now finished
big_wasa
posted on 22/3/21 at 11:34 AM Reply With Quote
6x20 with a 2.5" bore on mine its a very quiet with the turbo and a cat.
simon04
posted on 22/3/21 at 09:10 PM Reply With Quote
turbo motors are normally quieter than Nas.
6 inch is a good big size and about 600 to 700 long
Repackable if poss
HAve a look at tiger ot striker or the other big boys like westfield and caterham
J666AYP
posted on 23/3/21 at 08:21 PM Reply With Quote
Thanks for the input gents, appreciated.
Just to confirm does a 'Q' plate need a cat for the IVA? Seem to be getting conflicting information online?
J
obfripper
posted on 23/3/21 at 08:51 PM Reply With Quote
J
For the iva you'll need to pass the test applicable for your engine, that should be a cat emissions test for your merc engine unless it's pre aug 1994 which i guess is unlikely.
As the donor was capable of passing a cat test, so long as you have a reasonable size/quality cat fitted there shouldn't be a problem, the original one being the best option if you still have it.
Once iva is done, if you're on a 'q' plate, then for mot you will only require a visual check.
Dave
J666AYP
posted on 23/3/21 at 11:46 PM Reply With Quote
Thanks Dave,
Thats cleared up the confusion for me
J
