Author: Subject: Which Clutch Zetec to Type9
Mr.P
posted on 10/4/21 at 02:10 PM Reply With Quote
Afternoon Guys
I have a Tiger Avon with a 2.0 zetec blacktop, coupled to Type 9 Box
I currently having the engine rebuilt and while its out I may aswell replace the clutch. My question is which one do I require.
I have measured the friction plate which is 215mm dia. From what I have found I believe its a Pinto Clutch but can anyone confirm please ??
Pat
big_wasa
posted on 10/4/21 at 04:48 PM Reply With Quote
A 215 drive plate would be pinto plate. The 1.8 Zetec was 220mm
The cover plate could be either. If it’s in bits have a look at the thrust bearing depth or an extra set of drill and dowl holes in the flywheel
[Edited on 10/4/21 by big_wasa]
avagolen
posted on 13/4/21 at 09:03 AM Reply With Quote
HI,
I have the 1.8 silvertop Zetec and ended up using the Pinto friction plate and the Zetec pressure plate.
Release bearing used is the CT133.
I could not use the Pinto pressure plate as the bolts / dowels did not line up.
Hope this helps.
[Edited on 13/4/21 by avagolen]
