<<  1    2    3  >>
Author: Subject: Worryingly high oil pressure on Pinto engine
bumpy
posted on 11/4/21 at 07:56 AM Reply With Quote
Before being put into storage at the end of last Summer my car ran with normal oil pressures, generally about 50 psi when running hot.
For some unknown reason it now wants to run at 90 psi most of the time. Its like someone turned on a switch to just about double the pressure!!
I put in a new oil pump, two new filters, changed the oil from 20/50 to 10/30, tried two other oil gauges including a calibrated capillary gauge and took the head off to ensure no blockages to all accessible oil galleries.
Looks like I now need the experts. Please help.
cliftyhanger
posted on 11/4/21 at 08:11 AM Reply With Quote
Pressure relief valve stuck shut?
(I have zero Pinto experience, but all engines have a oil PRV to moderate pressure)
bumpy
posted on 11/4/21 at 09:08 AM Reply With Quote
Thanks, but as far as I know the pressure relief valve is part of the pump assembly, which was replaced in its entirety. Difficult to believe that both the existing and replacement pumps have the same issue
Does anyone know at what pressure the release valve operates?
posted on 11/4/21 at 09:15 AM Reply With Quote
It will be a stuck oil pressure relief valve , it's the only thing to control the oil pressure
bumpy
posted on 11/4/21 at 10:07 AM Reply With Quote
jacko
posted on 11/4/21 at 10:23 AM Reply With Quote
Just a guess is the pipe over the cam ok
I know you say the valve is new but thatís does not mean to say itís ok
Did you swop the pump like for like not a high capacity
Graham
[Edited on 11/4/21 by jacko]
Mr Whippy
posted on 11/4/21 at 12:56 PM Reply With Quote
First thing to do is confirm the oil pressure by fitting a test gauge. Most garages will have one. More often than not its the gauge is incorrect. If its an electronic gauge check the wiring and earthing.
View User's Profile Visit User's Homepage View All Posts By User U2U Member   Mr+Whippy 's Aim
bumpy
posted on 11/4/21 at 01:14 PM Reply With Quote
You must have missed that that has already been done (first post)
bumpy
posted on 11/4/21 at 01:16 PM Reply With Quote
Graham
Pump swapped like for like, but high pressure exactly replicated what was present on old pump.
And yes that spray bar was fully clear
[Edited on 11/4/21 by bumpy]
posted on 11/4/21 at 02:34 PM Reply With Quote
That was my thought - it could be a faulty oil pressure gauge or sender. Can you scrounge one from somewhere, just to try it out? Doesn't have to be anything grand, or calibrated, just a cheapo gauge to see whether it still shows an abnormally high pressure.
The older I get, the better I was...
bumpy
posted on 11/4/21 at 03:00 PM Reply With Quote
Still would like to know what pressure the release valve should operate at.
jacko
posted on 11/4/21 at 04:10 PM Reply With Quote
A standard oil pump works at 60psi at 6000 rpm a high pressure oil pump is 90psi
So I have just read on classic Ford forum
As a matter of interest where did you buy the new pump as I have just read burtons sell high pressure pumps
Graham
posted on 11/4/21 at 04:39 PM Reply With Quote
You don't expect me to read the WHOLE post, do you?
Apologies...
bumpy
posted on 12/4/21 at 08:55 AM Reply With Quote
Graham
It was indeed a Burtons pump OP1
https://www.burtonpower.com/std-oil-pump-sohc-ford-pinto-e scort-cosworth-t25-op01.html
Still doesn't answer the question why a car that ran all last year at normal oil pressures should suddenly double its oil pressure when re-started this Spring, when absolutely nothing had been changed ?????
CosKev3
posted on 12/4/21 at 09:13 AM Reply With Quote
Graham
Could well be a HP pump supplied by mistake?
And the old pump had a stuck relief valve?
CosKev3
posted on 12/4/21 at 09:15 AM Reply With Quote
Have you stripped old pump and checked relief valve piston?
jacko
posted on 12/4/21 at 04:31 PM Reply With Quote
Looks like the only thing you can do is sump off and check the relief valve there is nothing else that I can think of to cause your problem
Unless some one can think of something else
Graham
jacko
posted on 12/4/21 at 05:31 PM Reply With Quote
I think you may have answered your own question it must be a stuck valve
Of cause I could be wrong
CosKev3
posted on 12/4/21 at 05:37 PM Reply With Quote
It's the same with a brand new pump though?
bumpy
posted on 13/4/21 at 07:51 AM Reply With Quote
Old PRV was taken apart, and no sign whatsoever of it sticking
jacko
posted on 13/4/21 at 08:13 AM Reply With Quote
Well if you think it isnít the valve I donít know what it could be faulted oil gauge maybe but you say you checked that
Graham
r1_pete
posted on 13/4/21 at 09:14 AM Reply With Quote
Does the engine sound rattly as if its starving of oil? If so, something could be blocking the galleries close to the pump.
adithorp
posted on 13/4/21 at 09:23 AM Reply With Quote
Wasn't there some issue with Burtons oil pumps? Seem to remember something about the galleries not lining up properly that o read something about a while ago. Probably on a ford forum..
http://jpsc.org.uk/forum/
jacko
posted on 13/4/21 at 02:40 PM Reply With Quote
Did you put gasket past in-between the pump and pick up or pump to block ? If so it could have part blocked a gallery
[Edited on 13/4/21 by jacko]
steve m
posted on 13/4/21 at 06:28 PM Reply With Quote
@Bumpy
Can you repost EXCACTLY what has been changed on or in the engine since the oil pressure was around 50psi until now its 90psi
I have had similar problems on a xflow, when the Prv wouldnt open but was more around 70psi at tickover
<<  1    2    3  >>
