Author: Subject: Mondeo V6 Flywheel
liam.mccaffrey
posted on 2/6/21 at 09:56 AM Reply With Quote
Mondeo V6 Flywheel
Does anyone have a V6 Mondeo flywheel in their garage?
Would you mind checking the bore dimension for me? Looking for 44.5mm
Thanks in advance
Build Blog
Build Photo Album
View User's Profile View All Posts By User U2U Member This User Has MSN Messenger
big_wasa
posted on 2/6/21 at 10:05 AM Reply With Quote
Ive got a jag flex plate that's pretty easy to get to.
Could probably get to the flywheel Sunday if no one else has it to hand sooner.
Spigot bearing extension / housing ?
liam.mccaffrey
posted on 2/6/21 at 10:14 AM Reply With Quote
That would be amazing if you could check please! I'm installing a Volvo V8 into my Volvo 240 tintop.
I'm pretty sure this engine shares the same crank nose as the Ford/Jag V6 and i'm looking to source a flywheel.
I've just bought a flywheel from what I now believe is a diesel mondeo and it doesn't fit.
I'm looking to confirm its a 44.5mm bore with the 8 bolts on a 76mm PCD.
Thanks in advance.
Liam Mc
Build Blog
Build Photo Album
big_wasa
posted on 2/6/21 at 05:08 PM Reply With Quote
It looks like you are correct on all counts but I will see if I can think of a better engineering solution to measure it.
I would add the 8 holes are not of equal spacing so the flywheel will only bolt on in one position
[Edited on 2/6/21 by big_wasa]
liam.mccaffrey
posted on 2/6/21 at 05:20 PM Reply With Quote
you are correct the spacing is 45 except one hole which is 4 out. 45, 45, 45, 41, 49, 45.....etc
that is brilliant thankyou
do you happen to know if they ever came with a single mass flywheel and which years this v6 came in.
Build Blog
Build Photo Album
big_wasa
posted on 2/6/21 at 05:37 PM Reply With Quote
Yes the mk1 Mondeo 2.5 engine code Sea but I understand they changed to dual mass while still on the mk1.
Ford Cougar.
St24.
These are all the same unit.
There was a lighter one on the st200
big_wasa
posted on 2/6/21 at 05:47 PM Reply With Quote
And the ring gear has the same pitch as the zetec startermotor
liam.mccaffrey
posted on 2/6/21 at 06:29 PM Reply With Quote
That's all really helpful! Thankyou.
Build Blog
Build Photo Album
