Author: Subject: Rear road springs
jacko
posted on 9/6/21 at 05:44 PM Reply With Quote
Rear road springs
Hi all
On my Astra Sri I have had to change both rear springs ( broken) the springs fit both ways on the car but which is right
When fitted one end has two coils close together and the other end is more open
So my question is which way do I fit them ? Open coil at the top or bottom
Thanks Graham
adithorp
posted on 9/6/21 at 09:22 PM Reply With Quote
I'd go with open at the bottom but I've no idea if that's right or wrong, other than for some reason it looks right/better to me.
http://jpsc.org.uk/forum/
ian locostzx9rc2
posted on 10/6/21 at 05:50 AM Reply With Quote
As said wider coil at the bottom closer coil at the top makes the spring action more progressive
adithorp
posted on 10/6/21 at 06:37 AM Reply With Quote
Thinking about it a bit more, having the lighter open springs at the bottom reduces unsprung weight. The movements at the bottom are far larger and the open end has less mass.
I don't think from a compression point of view, it makes much difference.
posted on 10/6/21 at 08:42 AM Reply With Quote
1. A Haynes manual should tell you
2. A crafty call to a main dealer or garage
3. Look under the back of the same car in a public car park and see which way they're fitted
4. Do the springs you've bought not come with any fitting instructions (having bought replacement springs myself I know the answer's probably no)
gremlin1234
posted on 10/6/21 at 09:24 AM Reply With Quote
a quick look at an online parts manual, just shows the springs tappered at both ends ;-(
https://vauxhall.7zap.com/en/car/p10/m/0/3-1/
jacko
posted on 10/6/21 at 05:29 PM Reply With Quote
A big thankyou to all
the springs are not gen Vauxhall there a after market Iím not rich you know hehe
Iím putting them open coil down and forget them thanks again
Graham
