New Topic New Reply
Author: Subject: Sierra triangle steering column bearing
pekwah1
posted on 2/7/21 at 02:54 PM Reply With Quote
Hi guys,
I have a Sierra triangle upper column and need to sort out the support.
Itís currently sat through a rose joint but doesnít sit very well and just rubs round the hole.
Iím looking to replace this for a proper bearing that the triangle section would sit in nicely, anyone have any bright ideas as I canít find anything.
wonderfulweasel
posted on 2/7/21 at 03:37 PM Reply With Quote
Iíve used a pillow bearing with the same diameter as the original Sierra plastic bushing. I guess you may no longer have the plastic bushing though.
I think some companies do offer a bearing that has a similar diameter to the three points of the triangle, so that it sits snuggly inside. However, I may be wrong about this!
posted on 2/7/21 at 04:36 PM Reply With Quote
There was a post on here somewhere suggesting a self aligning bearing which I have used on my car , helps considerably with self entering as well
pekwah1
posted on 2/7/21 at 05:19 PM Reply With Quote
Hi yes I donít have a bush for the column, was also looking for one of these thinking Iíd just put that inside a bearing but canít find the bushing either
big_wasa
posted on 2/7/21 at 06:01 PM Reply With Quote
The Sierra bush is available as part of a kit but itís not cheap
eBay Item
The bearing is a 25mm self aligning pillow block bearing then you take a tiny bit of the bush for a nice snug fit.
[Edited on 2/7/21 by big_wasa]
procomp
posted on 4/7/21 at 05:46 PM Reply With Quote
Hi, i have loads of the bush kits ( i brought them when they where £1.50 ) give me address ill pop one in post FOC.
Cheers Matt
PS yes it is a 25mm or 1" bearing requires for the bush to fit in. 1" 25.4mm is perfect.
pekwah1
posted on 4/7/21 at 06:02 PM Reply With Quote
Hi matt,
What a gent! Have sent a U2U
New Topic New Reply
