Author: Subject: Brake Rotor Shims
UKKid35
posted on 13/8/21 at 04:58 AM Reply With Quote
Brake Rotor Shims
In order to centre a new rotor in the caplier, I'm hoping to get a 1mm shim made to go between the hub and the bell
Is that an acceptable thing to do, if so what material would be best?
Can they be bought off the shelf even?
Bolt Pattern (Lug Pattern) PCD 5x114.3
Center bore (hub bore) 71.5 mm
Theshed
posted on 13/8/21 at 07:07 AM Reply With Quote
Not an uncommon thing to do. Often found on Jaguar back axles. However may be easier to shim the caliper. If you use a soft shim there is a danger of the bolts coming loose. You cab buy shim stock in sheets - I think that is generally a hard steel.
Have fun
posted on 13/8/21 at 10:06 AM Reply With Quote
I too would shim the caliper.
You can buy shim washers in various thicknesses.
I used Shim washers to correct the rear toe on my MK Indy as the rear wishbones didn't have toe adjustment.
UKKid35
posted on 13/8/21 at 10:12 AM Reply With Quote
The bolt orientation on the CP5200 calipers means shims allow for an increased disc diameter
I'm going to stick with 320mm discs for now, but I'm switching to a 32mm thick disc
The current setup I have centres a 30mm disc
posted on 16/8/21 at 12:22 PM Reply With Quote
AS another solution:
If you're fitting different rotors can you not get different bells to suit the calipers and rotors, providing the correct centres?
UKKid35
posted on 27/8/21 at 03:46 PM Reply With Quote
Worked out well in the end
Here are the shims - They really are beautifully made
First I had to make sure that the wheel nuts were suitably tight
Now the clearance is equal each side
Great on the road, will hopefully get a chance to try on track within a few days
Mr Whippy
posted on 27/8/21 at 04:11 PM Reply With Quote
Looks perfect, nice one
View User's Profile Visit User's Homepage View All Posts By User U2U Member   Mr+Whippy 's Aim
