Author: Subject: Odyssey Battery
John Bonnett
posted on 21/8/21 at 05:25 PM Reply With Quote
Odyssey Battery
I was particularly impressed with the Odyssey Extreme battery that I fitted to the G15 BMW and would like to use a similar dry cell battery on the project. I'm using a 1.6 Sigma engine with EFI and air conditioning. The standard battery for the Focus is a 075. Can anyone recommend a suitable battery from the extensive Odyssey range please?
Thank you.
big_wasa
posted on 21/8/21 at 06:02 PM Reply With Quote
I had no problems with a Pc680 on both a 2.0 Zetec and a 1.8. Both Na and turbo with full efi, Twin fuel pumps, twin o2 sensors, high torque starter.
I have gone bigger for the dinosaur like 2.8 Cologne as it takes for ever to start once the fuel in the carb has evaporated.
John Bonnett
posted on 21/8/21 at 06:33 PM Reply With Quote
Ah, that's excellent information and not so expensive as I was fearing.
Thank you so much
kind regards
John
big_wasa
posted on 21/8/21 at 09:21 PM Reply With Quote
The T7 design billet battery tray for it is very nice if a little extravagant
Myke 2463
posted on 22/8/21 at 07:18 AM Reply With Quote
Alternative to PC 680
Check this https://www.tayna.co.uk/motorcycle-batteries/enduroline/ec680/ more cca and better price. or this one https://www.tayna.co.uk/motorcycle-batteries/xtreme/xr-600/?gclid=CjwKCAjw64eJBhAGEiwABr9o2AcKPnV7i-yrfTMRY6iGVVCu98QoEp2MDivTcKLN0DMVTnFuhmQfwRoCvP0Q AvD_BwE
[Edited on 22/8/21 by Myke 2463]
Be Lucky Mike.
sdh2903
posted on 22/8/21 at 11:18 AM Reply With Quote
I've used a couple of the second one in your links and have been spot on. The current one is spinning over a 3.0 v6 with no probs.
John Bonnett
posted on 22/8/21 at 12:54 PM Reply With Quote
That's good information and considerably less expensive than the Odyssey. I know nothing about AGM technology. Can it be laid on its side or does it have to me mounted upright?
perksy
posted on 22/8/21 at 02:57 PM Reply With Quote
I used the PC680 on a tuned 2 litre XE and its a good battery
The only thing to be aware of is they don't respond well if rundown flat, So they don't like parasitic drain etc over a period of time
I used to keep it on a trickle charger and/or use the battery cut off switch
sdh2903
posted on 22/8/21 at 05:10 PM Reply With Quote
The Agm can be laid flat.
They are remarkably capable considering their size, I was cranking the v6 over a lot before going for a full start during the build and it stood up well. Even over the winter I disconnected it when fully charged and left it for 5 months and it held its full charge.
John Bonnett
posted on 22/8/21 at 05:31 PM Reply With Quote
Thank you
