Author: Subject: Bolt fallen into tank oops!
macc man
posted on 30/8/21 at 05:19 PM Reply With Quote
While refitting the petrol flap on my MX5 I dropped a bolt into the tank. Will I need to retrieve it or will it cause no problems. Any thoughts.
Duncan Grier
posted on 30/8/21 at 05:36 PM Reply With Quote
While I have no idea of the mx5 setup most cars I have had the pleasure of playing with tank/fuel systems of cars which have in tank pumps also have a filter so unlikely to be an issue but would always be on my mind and if easy to get to whip the in tank pump out and drop a magnet stick or on a bit of wire etc to fish it out
Quinten
posted on 30/8/21 at 06:08 PM Reply With Quote
The filter should prevent it from travelling any further. Can you tilt the car to one side (to move the bolt into a corner) and then use a magnet on a stick to retrieve it?
snapper
posted on 30/8/21 at 06:35 PM Reply With Quote
https://www.amazon.co.uk/stores/SilverlineTools/page/42484CEA-9D4D-44C5-843D-0CF247691BF5?ref_=ast_bln
Flexible pickup tool
I eat to survive
I drink to forget
adithorp
posted on 30/8/21 at 06:45 PM Reply With Quote
Forget it. It won't do any harm. There's probably an anti-syphon valve/flap and youight get a flexi probe stuck in it... Don't ask how I know
http://jpsc.org.uk/forum/
perksy
posted on 30/8/21 at 07:05 PM Reply With Quote
As above, It'll be fine
Helped with an old Volvo once though with an intermittent fuel starvation problem and that had a piece of wet & dry in the tank
theconrodkid
posted on 30/8/21 at 07:37 PM Reply With Quote
pah, when i was doing breakdowns, i went to an old escort with a fuel blockage, took the tank out and found someone had put a dead snake in the tank, snake was about a foot long
who cares who wins
pass the pork pies
View User's Profile E-Mail User View All Posts By User U2U Member   theconrodkid 's Aim   theconrodkid 's Yahoo
perksy
posted on 30/8/21 at 08:29 PM Reply With Quote
gremlin1234
posted on 30/8/21 at 08:38 PM Reply With Quote
only problem I can foresee
if it locates itself under the float for the fuel level; causing it never to read low.
macc man
posted on 30/8/21 at 09:20 PM Reply With Quote
I think I will see how it goes and wait for a problem. It could turn into a big job to remove it, Many thanks.
gremlin1234
posted on 30/8/21 at 09:54 PM Reply With Quote
oh, another thing it could do is 'rattle'
is it a steel bolt? in an ali or plastic tank? if so a strong magnet on the outside could pull it out of the way
[Edited on 30/8/21 by gremlin1234]
posted on 31/8/21 at 08:37 AM Reply With Quote
Tintop fuel tanks that I've had to deal with have had in tank lift pumps in them with a mesh basket around the pump to filter out crud. The fuel then goes though another filter in the engine bay. Appreciate you'll know it's in there, but I'd leave it myself - masses of time and effort to retrieve it when it can't do anything in there.
posted on 31/8/21 at 03:08 PM Reply With Quote
You need one of those fuel tank anti-python valves for that
gremlin1234
posted on 31/8/21 at 05:45 PM Reply With Quote
... and found someone had put a dead snake in the tank, snake was about a foot long
like
[Edited on 31/8/21 by gremlin1234]
adithorp
posted on 31/8/21 at 07:10 PM Reply With Quote
hellbent345
posted on 1/9/21 at 09:03 PM Reply With Quote
Knowing mx5 fuel tanks, although the fuel pump and sender assembly is easy to get at, the access you get into the tank with it removed is still poor, so the effort to remove it outweighs the risk so just keep it as it is. There is a large sock filter on the mx5 pump assembly so there is no danger of it blocking, and the sender doesn’t hit the bottom of the tank so you would still know it is low on fuel anyway. Might hear rattling but I doubt it.
All the above being said, are you aware that the fuel filler pipe has a large ball in it that acts (I believe) as a rudimentary roll over protection device? It is possible the bolt could be stuck at that point, if you could carefully remove the pipe from behind the flap in the boot you may find the offending article there..
gremlin1234
posted on 4/9/21 at 02:43 PM Reply With Quote
I think that was just the wrong fuel 'adder-tive'
