Author: Subject: Fuel Pipe Supplier
Gwg555
posted on 15/9/21 at 01:15 PM Reply With Quote
Fuel Pipe Supplier
Hi all,
Please could someone suggest a supplier where I can source a replacement fuel pipe for my XFlow - locost (Located between fuel pump and tank).
It's starting to fracture/leak at the bottom near the fuel tank connection. The writing appears to be in German and so was wondering what you guys recommend.
See pics for reference.
Thank you for your help.
Guy
https://www.dropbox.com/s/0srgprgivh661lh/Fuel%20Hose%201.jpg?dl=0
https://www.dropbox.com/s/qucsra86d3v3dqk/Fuel%20Hose%202.jpg?dl=0
loggyboy
posted on 15/9/21 at 01:56 PM Reply With Quote
Any R9 (SAEJ30R9) fuel pipe of the correct diameter should be fine.
Mistral Motorsport
Paul_Arion
posted on 15/9/21 at 03:03 PM Reply With Quote
Thats certainly looking a bit worse for wear. I'd be included to buy a few metres and replace all flexible fuel lines whilst you are at it
mcerd1
posted on 15/9/21 at 07:53 PM Reply With Quote
this Cohline stuff is meant to be good:
https://www.merlinmotorsport.co.uk/p/high-spec-rubber-fuel-hose-by-cohline-per-metre-2240-0600
I've got some to go on mine when I get round to it....
adithorp
posted on 15/9/21 at 09:12 PM Reply With Quote
Just beware of eBay and similar e-retailers as there's a lot of fake stuff marked up as approved.
http://jpsc.org.uk/forum/
Gwg555
posted on 15/9/21 at 09:26 PM Reply With Quote
Brilliant ok, thanks for your reply’s.
Guy
Grimsdale
posted on 16/9/21 at 09:25 AM Reply With Quote
I bought mine from here. rapid delivery iirc.
https://www.glencoeltd.co.uk/cohline-fuel-vacuum-hose/cohline-fuel-hose-high-pressure/cohline-2240-r9-specification-rubber-fuel-injection-hose-8mm-pus h-on-e85-compatible-2267/
40inches
posted on 16/9/21 at 09:53 AM Reply With Quote
I have always used CBS, not had any problems.
https://www.carbuilder.com/uk/ethanol-proof-fuel-hose-8mm-516
Oddified
posted on 16/9/21 at 03:17 PM Reply With Quote
I also use that (8mm and 10mm), very very good stuff and it's been on my car for several years now and is still as soft/rubbery (if that's a scientific test lol!) as the day it was fitted
View User's Profile Visit User's Homepage View All Posts By User U2U Member   Oddified 's Aim
r1_pete
posted on 16/9/21 at 07:03 PM Reply With Quote
Been using Cohline from CBS for a couple of years now with no problems at all.
This R9 came from a 'reputable' supplier, its not just ebay you need to be wary of...
R9r9r9
R9r9r9
Sanzomat
posted on 16/9/21 at 07:07 PM Reply With Quote
I've had R9 go like that in just three years with E5 so guess it would only take 2 or less with E10. Mine was from a proper supplier too. Next time I'll be going with teflon or suchlike as it seems that even the higher grade NBR, supposedly good for E85, is only good for a couple of years at best.
indykid
posted on 17/9/21 at 08:42 AM Reply With Quote
Can you state your 'reputable' suppliers supplying suspect hose please so we know the lay of the land?
Not for a witch hunt, just due diligence
me? ambivalent? well, yes and no
sdh2903
posted on 17/9/21 at 10:10 AM Reply With Quote
Just use gates barricade. Might be more expensive but will last much longer. Just make sure its genuine gates stuff though.
James
posted on 17/9/21 at 11:59 AM Reply With Quote
This is a great thread to refer back to.
As always- thank you David Jenkins!
https://www.locostbuilders.co.uk/forum/9/viewthread.php?tid=153126
View User's Profile View All Posts By User U2U Member   James 's Aim
loggyboy
posted on 17/9/21 at 12:50 PM Reply With Quote
I think where possible its best to switch to metal lines and try and find some OE plastic lines that can be cut and made to fit where movement is needed. Rubber hose is pretty much unheard of in OE applications now.
[Edited on 17-9-21 by loggyboy]
Mistral Motorsport
posted on 17/9/21 at 03:13 PM Reply With Quote
What annoys me is that when I fitted my bike carbs I fitted a bike fuel pump. This has a length of flexible pipe that doesn't feel anything like the usual reinforced rubber, but it's been flawless ever since I installed - and I can't find out what it's made of!
The older I get, the better I was...
