Author: Subject: Which sealed connectors ?
mcerd1
posted on 7/1/22 at 09:27 AM Reply With Quote
I'm getting to the point where I'm going to have to start wiring this car (and I hate wiring )
there are a few places I could do with splitting off part of the loom for ease of fitting/maintenance and inevitably a few components needing connectors too
Obviously I'd like to stick to a single system (where possible) and needless to say its got to be 100% reliable - so before I rush out an buy into a system and a proper matching ratchet crimp tool, what are your thoughts on which type: Super seal, Econoseal, JPT, Deutsch or something else ?
(the Deutsch crimp tools I've found so far don't seem a cheap option )
roadrunner
posted on 7/1/22 at 10:38 AM Reply With Quote
I purchased this set from Ebay as I needed to sort mine out. The back of the dash is a Hornets nest of wires.
Linky
jacko
posted on 7/1/22 at 05:58 PM Reply With Quote
Linky
There the same type as we use at work very good
Graham
posted on 8/1/22 at 02:26 PM Reply With Quote
Whichever type you go for using the proper crimping tools makes a big difference. Usually ratchet type tools rather than plier type tools.
Charlie_Zetec
posted on 10/1/22 at 05:06 PM Reply With Quote
Linky
Another vote for these - used when I installed the entire auxiliary loom in my Defender for all the bolt-on goodies! 5 years on, and still got no issues. As others have said, use the proper ratchet crimpers for the pins though (it's not the same as ones used for butt-crimps).
I've also used Deutsche connectors before, but as you found out, they're not cheap. I only used them as some items came with a pre-wired & molded plugs attached.
