Author: Subject: Best carb
joneh
posted on 15/1/22 at 09:28 AM Reply With Quote
Best carb
Hi all,
Been a while since I was last here, been very busy at work and started a new job. My other hobbies of sailing, bee keeping and allotment are paused for the winter so I have tinkering time.
I have a 1300 xflow which I got running last year but I'd like to replace the twin 40s with something a bit more suitable and easier to tune and maintain. (And cheaper to run)
Is the 28/36 DCD the best choice?
Anyone have one for sale I can bolt on and fire up?
Thanks!
Jon
r1_pete
posted on 15/1/22 at 10:08 AM Reply With Quote
If you can find one, in my opinion the 34/36 dgv weber on the Escort 1300GT manifold takes some beating for reliable road use, you probably wouldn't notice much loss in performance either, then again I've never been a big fan of the dcoe type carbs.
I had a 1300 Mk3 Cortina with a 34/36 escort set up, transformed the underpowered barge.
Ebay item 334283546990
[Edited on 15/1/22 by r1_pete]
Mike Wood
posted on 15/1/22 at 10:55 AM Reply With Quote
Hi
750 Motor Club Locost racers with 1300cc run with a downdraft Weber, see:
http://www.750mc.co.uk/formulae/locost.htm
https://www.750mc.co.uk/ugc-1/1/1/0/2021_locost_-_final_regs.pdf
What do you want to use the car for and what car is it?
Do you want to sell your twin 40 Webers jetted for a 1300 Crossflow? Are these are on a short inlet manifold (i.e. might fit in a Locost?). What spec is the engine including camshaft?
Mike
[Edited on 15/1/22 by Mike Wood]
joneh
posted on 15/1/22 at 12:50 PM Reply With Quote
Hi
Thanks, will see what I can find, unless anyone on here is selling something.
I would sell the twin 40s but they're not matched and need a complete overhaul. They're on the 1300 manifold which clears them of the distributor etc.
Just finished the cooling system and went to restart and the starter isn't engaging. Sigh.
Jon
Mike Wood
posted on 15/1/22 at 01:10 PM Reply With Quote
New downdraft twin choke Weber 32/36 DGV carbs are available from Eurocarb: https://www.dellorto.co.uk/shop/weber-carburettors-parts/weber-twin-barrel-carburettors/dgav-dgv-carburettors/weber-dgv-5a-3236-carburettor/
(or https://www.dellorto.co.uk/shop/weber-carburettors-parts/weber-twin-barrel-carburettors/dgav-dgv-carburettors/weber-dgv-5a-3236-carburettor-with-synch ronised-butterflies/
Or https://www.dellorto.co.uk/shop/weber-carburettors-parts/weber-twin-barrel-carburettors/dgav-dgv-carburettors/22680-872-weber-dgav-32-36-carburettor-k it/)
They also sell carb refurb kits if you can find a secondhand carb.
https://www.classicfordmag.co.uk/tech/tech-weber-dgv-rebuild-instructions/
Why not try posting a wanted ad in the ads section or on the racing section of this forum?
Also Classic Formula Ford cars use this cab IIRC, so maybe worth asking such racers and their suppliers. https://www.classicformulaford.co.uk/
https://hscc.org.uk/championships/historic-formula-ford/
https://www.hartwell.co.uk/pages/ford/formula-ford-parts/
Mike
Deckman001
posted on 15/1/22 at 04:01 PM Reply With Quote
Hi Jon,
Another thing to bare in mind is your bonnet height and lines, as with bike carbs, you can probably keep them under a full bonnet, but a down draught will probably need a hole cut in the said bonnet to allow it and or the filter to go through.
Your 40's on a manifold will probably allow no cut outs needed, similar to bike carbs. I am no good with fibreglass hence why i have kept with bike carbs to prevent any f/g cutting and finishing nicely needs.
joneh
posted on 15/1/22 at 04:10 PM Reply With Quote
I had an old motorcraft carb and you're right, it didn't fit. The 40s don't either though I'll be cutting either way...
posted on 15/1/22 at 04:14 PM Reply With Quote
Originally posted by joneh
Hi
Jon
I have a complete manifold, Weber 32/36 DGV carb and throttle linkage, together with a throttle-position sensor for sale if you're interested. Complete with 2 filters (2 different sizes), and the oil separator box and manifold connector (I think). The carb hasn't done many miles since new. Currently jetted for a 1660 Xflow engine, and I got roughly 100 BHP when on the rolling road.
PM if you're interested.
The older I get, the better I was...
Mr Whippy
posted on 16/1/22 at 11:58 AM Reply With Quote
Is it worth considering converting it to injection? Even single point would be better than a carb and it would improve your mpg which given the cost of petrol these days would be very helpful.
View User's Profile Visit User's Homepage View All Posts By User U2U Member   Mr+Whippy 's Aim
joneh
posted on 16/1/22 at 12:52 PM Reply With Quote
Yes, but budget won't stretch that far. I have too many expensive hobbies!
Dingz
posted on 19/1/22 at 02:41 PM Reply With Quote
Iím pretty sure I have a 1300gt carb but no linkage or manifold, I can make sure at the weekend if you were interested.
went on and on.
joneh
posted on 21/1/22 at 05:42 PM Reply With Quote
OK, please let me know cost, condition etc.
Dingz
posted on 22/1/22 at 04:11 PM Reply With Quote
It's a 32 DGAV 5E choke sizes are 23 and 24 If you send me a pm with your email I'll send you some pictures.
went on and on.
snapper
posted on 23/1/22 at 04:40 AM Reply With Quote
Injection is a very expensive option and wonít give anymore performance than a well setup carb, you may get a smoother torque curve and slightly better fuel consumption but both with a 1300 Crossflow should be reasonable anyway.
I eat to survive
I drink to forget
