Author: Subject: Engine and gearbox mount dilemma
pitesy
posted on 18/1/22 at 03:14 PM Reply With Quote
Hi guys,
I am currently in the middle of preparing my FC3S rolling chassis to have an engine swapped in it.
The engine I have for it is out of an MX-5, the 1.8 vvt version. If I want to have the engine behind the steering rack, but still clearing the firewall, so I have to mount it with pretty tight clearances. Because of that I need mounts, that don't allow the engine moving too much and don't sag overtime (too much at least).
This lead me to a dilemma about engine and gearbox mounts.
I currently have a set of 95D (not shore A, but D, so bowling ball and hard hat hardness) engine and gearbox mounts meant for an M20 engine in an E30 (made by AKG in the US). They feature a straight through bolt, so they are pretty much solid when mounted. Which might give me problems with the "agricultural" 4 cylinder BP engine (these are meant for smooth inline 6's). People warned me about breaking stuff and bolts getting loose with the harmonics of the 4 cyl engine.
What is your take on engine and gearbox mounts? I have these ideas in mind:
- either get some softer polyurethane ones where the bolt on each side are not connected and allow some movement
- use the Jaguar V12 / Landy Defender / E30 M20 HD rubber /any other hard rubber mounts for both engine and gearbox
The car will only be used on track days, so extra NVH is not a concern, but bolts falling out and brackets snapping is. It is also important, that they don't allow the engine to move around too much.
Thanks a lot for your help!
Best regards all the way from Hungary
Stefan
jacko
posted on 18/1/22 at 04:54 PM Reply With Quote
Why not solid mount the engine and box by using suspension nylon mounts
G
pitesy
posted on 18/1/22 at 05:03 PM Reply With Quote
Thanks a lot for your input!
I've heard too many conflicting things about solid mounting. Some say it's okay and nothing will happen, others are convinced it will break crankshafts, gets all my bolts loose and will break unexpected things.
What I currently have are these:
https://www.akgmotorsport.com/product/motor-and-transmission-mount-set-for-bmw-e30-325-polyurethane-75d/
They are polyurethane, but a really hard one. Not sure how they compare to nylon?
theconrodkid
posted on 18/1/22 at 05:28 PM Reply With Quote
IMHO things like brackets will crack due to the vibes, land rover mounts are the bust to use in my opinion
who cares who wins
pass the pork pies
View User's Profile E-Mail User View All Posts By User U2U Member   theconrodkid 's Aim   theconrodkid 's Yahoo
RussH
posted on 18/1/22 at 06:15 PM Reply With Quote
I have very hard engine mount in my mx5 track car - everything rattles like crazy!
Duratec Westfield
RWD Focus
posted on 18/1/22 at 07:32 PM Reply With Quote
Speak to someone GMT rubber, all my mounts come from those for every engineering application/project we ever do.
https://www.gmtrubber.com/
Hope this helps
Richard
posted on 19/1/22 at 09:05 AM Reply With Quote
Agree - that is what I used on my MK Indy with a Ford Sierra Pinto engine and Type 9 gearbox. Very little engine movement and it did not give bad vibration in the car.
Mr Whippy
posted on 19/1/22 at 01:48 PM Reply With Quote
I tried solid mounting my pinto to my JBA Falcon, started it once and immediately changed my mind. Car sounded 10 times louder and vibrated like crazy. Best mounts are genuine diesel mounts for Landy or Transits, if your after comfort.
View User's Profile Visit User's Homepage View All Posts By User U2U Member   Mr+Whippy 's Aim
pitesy
posted on 19/1/22 at 08:21 PM Reply With Quote
Thanks a lot for all your replies! Let me just go one by one:
Indeed, vibrations cause these cracks. More and more people advise the land rover mounts. I am only unsure about how much engine movement I would have with those. Thank you!
Do you maybe remember what kind of mounts they are? Thank you!
Hope this helps
Richard
Never heard of them before, thank you! I'll get in touch with them.
Thank you! It's good to hear the engine does not move much. Do you maybe know if the mounts sagged overtime?
Comfort is not a priority, as the car won't get used on the street, but I'd like avoid bolt backing out, or other issues. I will look into the landy mounts now, those got lots of votes already. Thank you!
posted on 20/1/22 at 08:28 AM Reply With Quote
pitesy
The mounts didn't sag over the time I built and ran the car for 3,000 miles. They're pretty solid blocks of rubber! Don't know if MK Sportscars still supply them, but you could start looking on there website (I built my MK Indy 2003-2007 though).
pitesy
posted on 20/1/22 at 03:15 PM Reply With Quote
Thanks a lot Nick!
That is good news. I think I'll just buy those as engine and gearbox mounts as well. Leaving 10-15mm clearance everywhere should do the trick.
I was told with solid-ish and hard poly bushings you won't need more than 3-5mm (especially above the steering rack for example), but with rubber 10-15mm should work probably.
