Author: Subject: Stylus Help Needed - Panhard Rod
Fury1630
posted on 27/2/22 at 03:27 PM Reply With Quote
Afternoon, my Stylus' panhard rod chassis bracket hits the ground occasionally & it doesn't look like the sort of thing JP would design, so I'm wondering if it's a later addition. Could someone post a photo of the chassis end of the panhard rod please? Mine needs re-engineering & an idea of what JP had in mind would be good.
westf27
posted on 27/2/22 at 05:24 PM Reply With Quote
In your archive there is a picture showing a diff with driveshafts,so do you mean panhard rod or link arm.
Send me your email and I will copy mine to you.Mine runs an escort axle.
555
adithorp
posted on 28/2/22 at 02:06 PM Reply With Quote
Those pictures are his Fury not a Stylus that he's referring to now.
A picture or two would help. From what I can remember the lower tie bar mountings are pretty low but the panhard is above the axle
http://jpsc.org.uk/forum/
Fury1630
posted on 28/2/22 at 03:44 PM Reply With Quote
All sorted now thanks, the "standard" set up has the panhard rod bolting into the lower outboard corner of the rear bulkhead, mine had a quite nasty "leggey" bracket - now re-drilled further up & shortened, with a back up plan in csae it still bounces.
number-1
posted on 28/2/22 at 04:12 PM Reply With Quote
If you don't get an answer on here, try the Facebook SSC stylus owners page.
Edit...sorry....i didnt see the above post. Glad its sorted.
[Edited on 28/2/22 by number-1]
Fury1630
posted on 28/2/22 at 04:18 PM Reply With Quote
Got an answer now thanks.
Can't do Face book, I'm banned. No idea why, I joined one day, the following day I got a message saying I was banned, no explanation. Hadn't sent anything. So I just thought "up yours then"
