Author: Subject: 12mm diameter front wheel spindle
designer
posted on 13/3/22 at 06:41 PM Reply With Quote
Doing some drawings and 'want' to have a front wheel spindle of 12mm diameter for a lightweight, 200cc powered cart.
Any thoughts? Any metalergist here to recommend a material? Or am I totally wrong on going so small?
Mike Wood
posted on 13/3/22 at 08:32 PM Reply With Quote
Are you tempted to try using some secondhand kart spindles/stub axles, e.g. https://secondhand-karting.co.uk/cat/759/axles-and-running-gear ?
Mike
[Edited on 13/3/22 by Mike Wood]
ReMan
posted on 13/3/22 at 09:47 PM Reply With Quote
no expert , but 12mm feels a bit small for a stub axel on a powered vehicle
www.plusnine.co.uk
∙،. ˘≈ﺣ
View User's Profile Visit User's Homepage View All Posts By User U2U Member   ReMan 's ICQ status
indykid
posted on 14/3/22 at 08:13 AM Reply With Quote
We'd need a lot more information to make an informed decision, but assuming you're looking at a cantilever spindle and a sensible bearing span and wheel sizes for something with a 200cc motor, it's too small in steel.
I haven't run any numbers but if you go into exotic heat treated steel or titanium to make it work on paper, you're then into joining issues to tie it back into the uprights because you'll need flanges so it's not 12mm bar anymore. You're going to end up with very little factor of safety or a very dubious load case for your design calcs, regardless of the material.
What's making you think of using 12mm spindles?
me? ambivalent? well, yes and no
designer
posted on 14/3/22 at 10:05 AM Reply With Quote
Most thougts match what I was thinking.
Don't want a lot of rolling resistance so am using scooter tyre, and the spindles are usually around 11mm (Burgman) and 12mm (Lexmoto)
Might have to have a loop like the Eco-Exo.
indykid
posted on 14/3/22 at 12:53 PM Reply With Quote
Is your username intentionally ironic? That's a face only a mother could love!
It might be ok for your application, but it can't be good for dynamic camber control. Toe must be even worse.
posted on 16/3/22 at 11:37 AM Reply With Quote
Some uprights I fabricated a few years back for an unpowered soap box cart. M8 bolts used for the spindles to mount wheelchair wheels.
I wouldn't trust it for a powered vehicle myself (even if it were professionally fabricated).
[Edited on 16/3/22 by nick205]
