Author: Subject: MIG Welding gas suppliers
Bluemoon
posted on 13/5/22 at 03:31 PM Reply With Quote
Hi All,
I need to get hold of some welding gas.
What do you recommend?
- just learning to MIG mild steel - I have a repair on 19mm box (1mm thick). Will use 0.6mm wire.
Seems
Hobby weld 5,
or Adams gas (95% argon, 5% CO2)
Are available,
any other thoughts?
Dan
View User's Profile View All Posts By User U2U Member   Bluemoon 's Yahoo
big_wasa
posted on 13/5/22 at 06:37 PM Reply With Quote
My local welding supplier does there own as many now do. The local hobyweld guy is great as he is more flexible on collection out side the 9~5 but his workshop recently burnt down.
I havenít been brave enough to see how prices have changed in the last six months. What sort of prices are you getting ?
loggyboy
posted on 13/5/22 at 09:54 PM Reply With Quote
For small bits, £15 disposables from halfords. Did my rollcage plates on 2.5 of them
Mistral Motorsport
Slimy38
posted on 14/5/22 at 07:33 AM Reply With Quote
Adams gas or Hobbyweld are the best options, particularly as they don't do rental on their bottles. Just a deposit and you're sorted. You will need a regulator though, I recommend a twin gauge one as they are easy to work with.
The main issue I have (with Adams Gas but I think Hobbyweld will be the same) is that stockists vanish quickly. I've had four refills from three different suppliers, purely because previous people have just stopped doing it. Or they concentrate on trade tanks and don't stock the hobby size tanks.
Just checking now, the stockist that I got my last refill from six months ago has also gone...
obfripper
posted on 14/5/22 at 01:37 PM Reply With Quote
I use sgs gas and target gas from several suppliers, but they are west/southwest orientated, i don't know how much else of the uk they cover.
On the supplier end, they purchase pallets of gas bottles and set their own prices, prior to brexit/covid there had not been any wholesale price rises from sgs for the gas since 2008, but the retail price had risen quite a bit in that time from some suppliers but not others, so shopping around is necessary.
It looks like gas prices have generally risen since i last refilled, as boc are now £150 rental/yr and £100 refill for a size y(20l) bottle, my last target argon bottle was £180 including bottle deposit, and at the time £60 for a refill which was the same as boc (ignoring boc having 15% more gas due to pressure differences).
Dave
posted on 14/5/22 at 03:00 PM Reply With Quote
Adams Gas is really centred around Margate in Kent, for better or worse. Outside of the extreme south-east of England (Kent and neighbouring counties) you may struggle. I am lucky in that there is an agent near Bury St Edmunds, a town we visit quite often (I live just south of Ipswich). The major advantage of Adams Gas is that they don't charge rental on their cylinders - if you're a first-time buyer you pay the cost of the gas, plus a refundable cylinder deposit. This is a major concern when I want argon/CO2 mix for my MIG welder, which I only use occasionally. Using BOC gas (which I used to do) would cost me an absolute fortune in annual cylinder rental, for gas I use rarely.
Every cylinder I've had from them has looked near-enough new and in very good condition. I have no compaints about them.
The older I get, the better I was...
Slimy38
posted on 15/5/22 at 08:18 AM Reply With Quote
I did have several local suppliers in the Midlands, the first one was about 3 miles from me so that was the best option. That business completely closed so there was another a bit further away for my next tank. They stopped doing the hobby gas (although they were still listed as a trade gas supplier) so I went a bit further away.
This next one was my favourite, a car restoration shop that had some beautiful cars to look at. My wife started to wonder why it had taken a couple of hours to travel 10 miles!! He just did the gas on the side, he had a cage of tanks by his workshop. I'm guessing it was either so he had easy access to gas or he got a bit of a discount.
Sadly they're no longer on the list so I'm now up to 17 miles away for my next one. This one seems to be a regular MOT garage. If it gets much further then I might switch to Hobbyweld, as they now have a supplier a couple of miles up the road that wasn't there before.
posted on 15/5/22 at 10:46 AM Reply With Quote
I have a bottle of argon from Adams gas but my now nearest suppliers is 40miles away , My CO /argon bottle is from my local motorfactors who will also deliver to me . Check out your local motorfactors!
OliilO
posted on 15/5/22 at 11:17 AM Reply With Quote
I got mine from Cassell Welding in Reading recently. He does small and large bottles of Hobbyweld.
Not on your doorstep but not far away.
http://cassellwelding.com/index.htm
posted on 15/5/22 at 12:24 PM Reply With Quote
Motor Parts Direct motor factors supply welding gas. You can check on their website for your closest branch.
Failing that look for a local welding supplier. Many supply gas.
trextr7monkey
posted on 15/5/22 at 09:48 PM Reply With Quote
Used BOC then Hobbyweld but recently moved to Albee gas after picking up an empty bottle- it has a regulator fitted and the stockist is about 4 miles away. Itís a French company but I think theyíre nationwide
MikeR
posted on 16/5/22 at 07:32 AM Reply With Quote
If you're welding thin stuff try to get an argon mix, it's a little cooler than co2. Will be a little easier to learn but more expensive.
posted on 16/5/22 at 08:20 AM Reply With Quote
It's also much cleaner, with far less spatter, and a lot less "frantic" when welding. You just get a steady (loud) fizz and its a lot more controllable.
motorcycle_mayhem
posted on 16/5/22 at 09:26 AM Reply With Quote
Out of those two, I'd go Hobby Weld 5, based on my experience (MIG, mild steel). No rental, just remember to carefully file the paper you get with the first bottle (so you can get your deposit back when you terminate). MIG sips gas economically. If/when your gas demand becomes greater, I'd say go to BOC. Refill costs are cheaper, but you get the bottle rental. Argoshield light is what you want from BOC. I use BOC as well (Argon, not a mix) for the TIG, which consumes gas heavily, but in an emergency it'll MIG reasonably well on mild steel too.
posted on 16/5/22 at 12:30 PM Reply With Quote
I'd agree with comments above Argoshield works better for me when MIG'ging mild steel.
I've tried the disposable CO2 canisters. The MIG doesn't run as smooth for me and I probably end up using the CO2 faster than Argoshield to try and compensate.
ETA - if you find a local welding supplier they'll probably do rent free bottles. Slightly higher initial cost as you're paying for the bottle + gas. After that it's an exchange empty bottle for full bottle with the same welding supplier.
[Edited on 16/5/22 by nick205]
Bluemoon
posted on 16/5/22 at 01:16 PM Reply With Quote
Thanks for, the helpful info.
Wish to avoid bottle rental - I will not use enough gas. However, I can split the cost with a friend who is also keen on doing some welding.
Adams gas appears to have a few distributors near ~12miles (not ideal but not so bad) - as does hobbyweld. Addams seems better value however, 2^m3 for the same cost at 1.3m^2 from hobby weld.
We will see if anything more local - but can see having a more "national" distributor when the time comes to re-fill/return the deposit.
Regards,
Dan
SJ
posted on 16/5/22 at 03:03 PM Reply With Quote
Me too. I've got through three so far on my MGB restoration. One more shoudl see it done.
MikeR
posted on 16/5/22 at 05:49 PM Reply With Quote
If you're looking at disposable, check online at Amazon and eBay. Just be sure to check the size on case they're different (make sure you're comparing apples with apples)
JonBowden
posted on 17/5/22 at 10:24 PM Reply With Quote
I get my gas (pure argon for TIG) from BOC. Mostly as the agent is nearby. The cylinder is big, size Y. Cost a bit over £60 per year rental and about the same for a refill. Last time I checked it worked out cheaper than alternatives.
Jon
Dingz
posted on 20/5/22 at 10:47 PM Reply With Quote
If your local to Bedfordshire try GGB services at Old Warden, Iíll have to declare some interest as itís run by a former work colleague.
went on and on.
