tegwin
posted on 22/5/22 at 09:53 PM |
Wisdom needed- tin top axle beam corrosion
My trusty 2001 polo is (over)due an MoT. Thought I’d have a look over it today and found a couple of holes in the rear axle/beam.
I last had it off 12 years ago to replace the bushes. At the time I scraped it down and painted it with chassis paint. All that paint is now peeling
off with fairly large chunks of surface corrosion… an entire gusset is now missing and there are holes.
It’s clearly a vital safety part of the car. Not sure I can get a new one any more there are very few of these cars in scrapyards now.
Could I get away with cleaning this up and welding extra plates on the weaker areas?
Only concern is that I’m not entirely sure how thick some of the remaining metal is…
The rest of the car is acceptable, I’d say it’s got another 3 years in it before corrosion becomes an issue elsewhere.
What do people recon?
Sorry photos are rubbish. Will clean it up and get some more.
www.verticalhorizonsmedia.tv
ReMan
posted on 22/5/22 at 11:14 PM |
You can get new and refurbed ones of these. Its quite a common thing, not just VW's
Edited to say , quite a few decent 2nd hand ones on the bay too
[Edited on 22/5/22 by ReMan]
www.plusnine.co.uk
obfripper
posted on 22/5/22 at 11:17 PM |
It looks like you have a 6n polo, new axles are available for the 9n, but not for the 6n afaik.
I would get the axle blasted and see what remains, and how severe the pitting is before making a decision on repair.
I have replaced several 9n and 1j golf axles where the tube has badly pitted close to the weld and cracked/sheared off, at this point they are beyond
easy repair.
Dave
tegwin
posted on 23/5/22 at 06:53 AM |
It’s a 6n2 gti axle which unlike the standard 6n2 has disk brakes. It’s pretty rare. None of the refurb companies I’ve spoken to have these in their
systems any more.
There are two on eBay at the moment but both look suspiciously crusty. They are also a fair distance away. Might be worth a punt if they are a bit
better.
Will clean this one up a bit and see what is what.
daviep
posted on 23/5/22 at 09:51 AM |
Have you considered getting a good drum brake axle and transplanting the stub axles fron your axle. Looks like it would be relatively straight
forward?
tegwin
posted on 23/5/22 at 09:52 AM |
forward?
I don't think the standard 6n2 and the GTI axle is the same. Otherwise yes that would make sense.
posted on 23/5/22 at 10:24 AM |
All for the home mending and keeping things going, but I have to ask if the rest of the Polo is worth enough to plough much time, effort and money
into keeping it on the road?
If the rear axle beam's in that condition is the front subframe similar?
Is there much body corrosion, particularly in the sills, inner wings and floor pan?
tegwin
posted on 23/5/22 at 10:28 AM |
Oddly enough the rest of the car is nowhere near as bad as the rear beam.
Yes the corrosion is starting to creep in elsewhere but I don't think its quite worth scrapping it yet. The shell and sills are pretty much
perfect in condition.
Its a fun car to drive and with current car prices it just doesn't make sense to replace. Perhaps in 1-2 years time.
Its a hard one, this was the first car I bought and I still really enjoy driving it. Its got enough power and noise to really have fun on twisty B
roads without being illegally fast. Some more modern VW's and Audis I have owned are so quiet and numb you can be doing over a tonne and not
really feel it, which takes away from the experience for me. Plus I don't want a million touch screens...
[Edited on 23/5/22 by tegwin]
Mr Whippy
posted on 23/5/22 at 11:38 AM |
Personally I'd have no issues replacing any of the fabricated plating. The only part I'd not touch is the beam since that is flexing.
I've certainly seen worse as these rust due to not having the salt washed off after winter. I took my Fiesta beam off which is almost identical,
cleaned it and repainted with Hammerite before coating it with underseal. While it's off it's worth changing out the bushes and brake hoses.
Check the springs too as they tend to corrode, then snap.
posted on 23/5/22 at 02:43 PM |
I know that feeling weel - still my car of choice is a Peugeot 205 GTI. Yes they'll break the speed limit if you make them, but there's so
much fun in them without having to go to that limit.
tegwin
posted on 23/5/22 at 05:20 PM |
Balls!!!
I’ve had another look at the thing this eve. Took my chipping hammer for a walk all over it and found a significant lack of metal…. I think this is
beyond sensible repair 😭😥🫣
obfripper
posted on 23/5/22 at 05:38 PM |
Yep, unless you're going use it to design/build a jig and totally rebuild/remake, that axle is toast.
Good second hand is the best option now, but as you say the gti spec axle is pretty rare, iirc there were several seat ibiza cupra models that share a
disc braked axle, i'm not 100% sure that the geometry is identical though.
Dave
perksy
posted on 23/5/22 at 07:13 PM |
Think that's scrap and even if it was repairable its a safety critical item
Good secondhand one next step?
tegwin
posted on 23/5/22 at 07:31 PM |
Agreed!
Yes the hunt begins…. Concerned that the two on eBay may fall apart of i scraped off the paint …. Urghh
posted on 24/5/22 at 07:31 AM |
A 2nd hand replacement beam seems the best first option.
Failling that (much as it pains me to say it) it may be time to replace the car.
Mr Whippy
posted on 24/5/22 at 11:27 AM |
Considering this is a kit car/self build site, is it not possible to fabricate a new beam perhaps using the current one to create a wooden alignment
jig?
Once you have the jig, just cut off all the plate metal leaving just the hubs and torsion beam, bolt it onto the jig and start fabricating but this
time making it a sealed unit so it cant rust out. I'd use 2mm plate and a length of steel pipe for the arms, probably the same diameter that is
used for holding the bushes.
[Edited on 24/5/22 by Mr Whippy]
gremlin1234
posted on 24/5/22 at 12:50 PM |
our friends at clubpolo have a 'sticky' post about the changes involved fitting disks to the drum beam.
https://www.clubpolo.co.uk/topic/183803-how-to-convert-6n6n2-to-rear-discs/
unfortunately most of the the images don't work, even if you are a member:-(
but the text is good and shows you could get a 6n2 drum beam and convert it with the bits you have.
[Edited on 24/5/22 by gremlin1234]
tegwin
posted on 26/5/22 at 11:25 AM |
Isn't it weird how fate seems to strike...
I happened upon a guy on facebook that lives an hour from me. He has a little unit and breaks only 6n2 GTI's... He has quite an impressive
stash of stuff. Managed to get a better front subframe, hoping he will have a rear beam next week. One could spend an awful lot replacing all the
little bits on the car that have got mildly damaged over the years...
This is very quickly going to degrade into a full blown restoration isnt it...
Slimy38
posted on 26/5/22 at 12:43 PM |
That's how my brother in law started with his 91 Astra GSi, it didn't take long to go from 'that will be enough to get through the
MOT' to 'yes wife I'm working on the car AGAIN this weekend'...
Mr Whippy
posted on 26/5/22 at 04:00 PM |
Yip that's what happened to my Fiesta, clutch started slipping, next thing the suspension and engine were out and the thing up on stands for a
over year! way too easy to get carried away... Mind you I did find quite a few serious issues and whole underside was cleaned and treated. But still
have some more things to sort out I think it is in our nature to go overboard
motorcycle_mayhem
posted on 27/5/22 at 08:34 AM |
'Overboard' has been the nature all my life. Best one yet for me was the..... just weld in a new footwell.... (1967 Land Rover). 5 Years
later, one Trigger's Broom. Worth it financially? Definitely not (again, a recurring thing), but a helluva lot of blood, sweat, burns, fun and
personal satisfaction, you can't compare that to other folk's money worshipping lifestyle. Life is short, whatever lights your candle.
tegwin
posted on 27/5/22 at 08:57 AM |
Made some more progress last night...
Pulled the front sub frame off... same issue here... full of 'oles!
Minor irritation is that the subframe bolts into sliding "captive" nuts inside the chassis leg... One of the little buggers was rusted
solid so just spins and won't undo.. So a hacksaw had to be deployed...
So the next challenge is going to be to carefully open up the chassis leg to replace the captive nut
Mr Whippy
posted on 27/5/22 at 03:31 PM |
could you not weld a nut onto a large washer and then open the hole enough to then weld onto the washer (leaving a bolt in the nut to stop splatter
damaging the thread) as that might be an easier way?
Rusty subframes seem to be a plague these days. My Volvo had it's hot dip galvanised from the factory, it's spotless.
