DH2
posted on 12/6/22 at 06:04 PM |
Garage Clearance
Hi all.
Having now sold my project, it's time to clear out my accumulated parts that are now surplus.
Ford Type 9 Gearbox - standard box with short input shaft in good clean working order, selects all gears and turns over smoothly. Complete with a
cut-down lever, reverse switch, and brand new mount. £300.
Ford Type 9 Gearbox - standard V6 box, longer input shaft. Needs rebuild and has a bit missing from the rear of the tailcase. Also reverse lockout
missing.
£100.
Mini wiper motor - with bracket, rods and spindles, but no arms or blades etc. £30
Ford Escort Mk2 steering rack - genuine Ford rack case, standard ratio, all in good order, needs roll pins fitting to tie rods and gaitors. Also has
track rod extenders, steel mounts and rubbers. £50
Windscreen washer reservoir and pump - bag type reservoir with pump and tubing. £20
Battery master switch - FIA type, Autolec quality brand. £30
MX5 handbrake lever - from Mk1 MX5. £10
Sierra handbrake lever grip and sleeve - no lever. FREE
Ford Escort Mk2 handbrake lever - bit tatty, but functional. FREE
Sytec Fuel Pump and Filter - Walbro GSL392 type pump and bullet fuel filter. £50
Fuel Pressure Regulator with gauge - adjustable pressure regulator with integrated gauge. £30
Lotus Elise S2 heater controls - complete with push-pull control cables. £30
Vauxhall VX220 heater controls - no cables. £20
Ford Fiesta Mk6 heater matrix - FREE
Mazda MX6 column stalks - includes all basic functions with intermittent wiper. £20
Kozo RX2n multifunction digital dash gauge - complete kit including speedo pickup sensor. £150
Sterling Excel immobiliser - Thatcham Cat2 immobiliser, brand new complete kit. £75
Type 9 Gearbox Quick Shift - Rally Design item, brand new, complete with new saddle clip. £50
Powerflex PF99-111 suspension bushes - brand new, 7 packs of 2 bushes per pack. £25 per pack
Mazda MX5 brake calipers with pads - standard Mk1 calipers refurbished (by me) with all new pistons, seals, sliders, pads, pins, bleed screws
everything new. Castings cleaned up, treated with Kurust and painted with graphite caliper paint. All pistons are free moving and handbrake
mechanism working. Fitted with new Mintex 1144 pads all round. £250
Mazda MX5 brake discs - new standard front and rear brake discs. £50
Mazda MX5 front and rear uprights and hubs - standard Mk1 uprights, refurbished (by me) with all new bearings and hubs. Castings cleaned up and
painted with Hammerite. Also with new rear hub nuts, and caps (see next image). £300
Mazda MX5 rear upper bushes and lower bolts - genuine Mazda parts for rear uprights (excludes nuts and caps in photo). £50
Mazda MX5 front track rod ends - brand new First Line parts FTR5096, painted. £20
Mazda MX5 front lower balljoint - brand new Quintin Hazell parts QSJ3366S, painted. £20
Mazda MX5 / BMW front upper balljoint - brand new TRE parts JTE155. This is the BMW part to convert MX5 uprights to use a standard balljoint. £20
Compomotive CXR 13" alloy wheels - CXR1365, 13" x 6.5" wheels, 4x100 PCD (MX5 fitment NOT Ford), ET16 (lower offset than standard MX5).
At 5kg per wheel these are about the lightest cast alloy you can buy for sensible money. Never been fitted, have had tyres fitted and removed.
Satin Black finish. £400
Mazda MX5 standard alloy wheels - set of 4 14" 'daisy' OEM wheels, no tyres. £100
Pics to follow.
Please note prices do not include shipping. Collection is welcome, or I can ship if required (at additional cost - please ask).
Please ensure items are correct for you before buying. No returns, and no warranty given or implied.
Any questions etc please ask. I'll keep this thread updated as best I can when items are sold.
Thanks,
Dave
chillis
posted on 13/6/22 at 09:39 AM |
First dibs on the mini wiper motor and the mk2 rack please
U2U sent
[Edited on 13/6/22 by chillis]
Never under estimate the ingenuity of an idiot!
car man
posted on 13/6/22 at 12:08 PM |
Hi u2u sentry fuel pump
Partofthechaos
posted on 13/6/22 at 01:18 PM |
Blimey, that is a big clear-out! I'd be interested in the fuel pressure regulator if you still have it? I will send a U2U.
DH2
posted on 15/6/22 at 10:46 PM |
Steering rack = Sold.
Wiper motor = Sold.
Fuel pump & filter = Sold.
Fuel pressure regulator = Sold.
number-1
posted on 17/6/22 at 04:14 PM |
Ill take the VX220 heater controls.
I will u2u you
traveler.77
posted on 18/6/22 at 06:20 PM |
your Garage Clearance items
Hi mate, I'm interested in the £30 Mini wiper motor with bracket, rods & spindles, how much would it be to post the items to Telford TF1 5HN
traveler.77
posted on 18/6/22 at 06:22 PM |
Just seen your update on what's left - looks like the wiper motor has gone?
DH2
posted on 19/6/22 at 08:10 AM |
Yep, sorry, sold.
