Author: Subject: Gear ratio calculator/ Diff ratio/ top speed
m8kwr
posted on 10/8/22 at 07:55 AM Reply With Quote
Does anyone has a gear ratio calculator to work out top speed
I am trying to work out the best ratio diff to get for a bike engine car. I have found some posts about one, but the link is no longer available.
Any help would be greatly appreciated.
mcerd1
posted on 10/8/22 at 08:10 AM Reply With Quote
this one is still available: https://locost7.info/gearcalc.php
but the calcs aren't all that hard to do manually (and/or stick in a spreadsheet)
you just need to know the number of rev's pre mile for your tyre size (which you can lookup or calculate)
JAG
posted on 10/8/22 at 08:14 AM Reply With Quote
This website provides all the tyre data that you'll need
Tyre Size Calculator
Justin
mcerd1
posted on 10/8/22 at 09:00 AM Reply With Quote
in its simplest form its just converting rpm of the wheels into mph
if you know the effective diameter of the tyre (diameter of the rim + [2*profile*width] once you covert all to either mm or inches)
then Pi*D gives the circumference (probably in mm or inches depending on your preference)
then just convert 1mile into the same units (1,609,344mm or 63360" ) and divide by the circumference
but JAG's link above is easier
so you've got rev's per mile for the tyre (one way or the other)
an engine speed in rpm
a gear ratio
and a diff ratio
so for a given gear the calc goes a bit like this:
engine rpm (max. or maybe just after peak power - whatever your aiming for) - say 9000rpm for this example
gear ratio lets call it 0.82 (so 0.82 turns of the crank to 1 turn of the output [aka overdrive] typical for top gears on cars etc )
then the final reduction at the diff - say 3.62 (typical sierra V6 etc...)
so you can either do it step by step or multiply the ratios first and do it in one hit > 0.82*3.62 = 2.9684 (the overall gear ratio) then 9000rpm / 2.9684 = 3031.9rpm at the wheels
3031.9 * 60 = 181916 revs per hour
tyres - say 195/55 R16 with 862 revs per mile - so 181916/862 = 211 mph
but of course none of that accounts for your engine power or aerodynamics which will easily dominate at anything over 100mph
[Edited on 10/8/2022 by mcerd1]
mcerd1
posted on 10/8/22 at 09:16 AM Reply With Quote
if you want to get an approximation for actual top speed so that you can try to find gear ratio's to best fit it - then you need a calculator that works out drag and power...
the basic maths goes like this:
P = 0.5* p * Cd * A * V³
where P is the power in Watts,
p is air density (1.226),
CD is the coefficient of drag,
A is the frontal area in square metres,
and v is the velocity in m/s
so rearranging: V = cube-root ( P / 0.5* p; * Cd * A )
I ran the numbers based on my Dax:
P = 140hp = 104kW
Cd = 0.7 (approx. for most sevens / replica's some estimates are 0.65 some 0.75)
A = 1.85 (with windscreen)
V = 50.7m/s = 114 mph
and running it the other way aiming for a 150mph top speed:
150mph = 67m/s
Cd = 0.7
A = 1.85
P = 239kW = 320 hp
and thats all power at the wheels too.....
you'll find online calculator for this too, but they are mostly American drag racing sites
also I found this site which does the gear calc bit for you:
https://www.boosttown.com/gearbox_differential/speed_calculator.php
my previous link does still work, but the program doesn't like win10+ much
Edwardo
posted on 10/8/22 at 09:27 AM Reply With Quote
There is a 'sticky' literally the first line of the BEC section on the forum for this exact thing :-
Link to Sticky
I used it and after road testing it turned out to be spot on.
Tony
m8kwr
posted on 10/8/22 at 09:50 AM Reply With Quote
Thanks for the links and help. Appreciated. I shall look at it more in-depth later
Edwardo - that link unfortunately isn't working anymore, unless someone has the spreadsheet downloaded and willing to share with me also..
Edwardo
posted on 10/8/22 at 10:25 AM Reply With Quote
That's strange - I clicked the link and it opens up fine and downloaded the spreadsheet again this morning?
If you U2U me your email address I'll send it over
cliftyhanger
posted on 10/8/22 at 09:24 PM Reply With Quote
You can try this one
http://www.mintylamb.co.uk/gearspeed/
it is set up for Triumphs, but you can put in any gear/diff ratios you like. Does 4speed plus OD, and you stick in the tyre size.
Andrzejsr
posted on 11/8/22 at 09:38 AM Reply With Quote
https://www.blocklayer.com/rpm-gear
https://aswestfield.wordpress.com/
pmc_3
posted on 11/8/22 at 11:41 AM Reply With Quote
If you're on Facebook, that spreadsheet is in the BEC's Owners Group under the files tab https://www.facebook.com/groups/1116276415201811/permalink/1618296301666484
