Author: Subject: DTA S100 ECU, loom, paddle shift kit, AIM dash
cosmicicecreamman
posted on 1/11/22 at 09:23 PM Reply With Quote
Evening everyone,
Selling the entire ECU, wiring loom, paddle shift kit, digital dash and laptop from my track Sylva Riot.
The ECU is a DTA S100, the paddleshift kit is from Luke Algar from when he owned Playskool and comes with the paddle set, compressor, air pressure regulator, hoses, reservoir, valve set and throttle blipper. I've got two laptop cables also for using the DTA software and a laptop to run the software. The dash is an AIM MXS Strada and comes with the GPS08 module. There is also a wiring loom to go with it all with the AIM dash connected via CANBUS, but may need to be modified to suit whatever vehicle it was going into. There noise in the cam position wiring so this has been disconnected from the plug, so you would not be able to run sequential spark.
I know this may not be the target audience but if anyone genuinely wants all of it then I would be looking for around the £2,200 mark. I would rather see it all go to one person and to be honest would like to see someone on here get it.
1
1
2
2
Wiring loom
3
3
Air receiver with air pressure regulator and two different pressure switches
4
4
Compressor
5
5
DTA S100 ECU
6
6
Valve set with two gear change cylinders and throttle blipper
7
7
Gear change paddles
8
8
AIM MXS Strada digital dash (motorsport dash, not IVA compliant)
9
9
AIM GpS08 GPS module for AIM dash
Like I have said, this may not be the forum for this sale but if anyone is interested please let me know.
At this point I’m not looking to split the package as it comes as a whole working package.
Thanks, Stephen
RWD Focus
posted on 6/11/22 at 09:28 AM Reply With Quote
Would you sell the dash separately ?
Thank you
cosmicicecreamman
posted on 7/11/22 at 04:19 PM Reply With Quote
Good afternoon,
If there was interest for the rest of the kit without the dash then I would, but at this point I wouldn't sell it separately.
If this happens, I'll let you know.
Thanks, Stephen
gixermark
posted on 11/11/22 at 09:30 AM Reply With Quote
is the paddle shift system open loop based on timing or closed loop ?
cosmicicecreamman
posted on 12/11/22 at 10:07 AM Reply With Quote
Good morning,
I set the paddle shift up as closed loop with the potentiometer but it also has a time out function that you can set up if the loop is not closed.
The system is controlled via the DTA, with the paddles shift kit providing the hardware. All the information is in the DTA S100 manual which is easily obtained on the internet.
Stephen
