Author: Subject: Striker fibreglass tunnel
CRAIGR
Contributor
Posts 2762
Registered 30/8/05
Location Sussex
Member Is Offline
Photo Archive Go!
posted on 2/4/23 at 06:55 PM Reply With Quote
What year Striker had a fibreglass tunnel with inboard suspension as per mk2 ?
Paul A
posted on 17/4/23 at 11:42 AM Reply With Quote
It must be early as my brothers kit baught in about 95 was ali tunnel.
Paul A
yogibear1969
posted on 18/4/23 at 07:48 AM Reply With Quote
If you look for the Sylva history on the website, it should explain better. IIRC this was a budget version, commonly known as Mk3? I don't think JP made many.
Edward
JimSpencer
posted on 19/4/23 at 08:00 AM Reply With Quote
Hi
That's a good one - the answer probably should be 'none' but.. that doesn't mean there aren't any as there's a few unusual ones about.
The Mk3 was built from 88 to 90, Outboard front end and most had a fiberglass tunnel, but one or two didn't, they we're built with a Mk2 tunnel - for, one assumes, a very good reason at the time - i.e. that's what the customer wanted? going racing??
(I have one..)
So - at a guess a Mk2 with a fiberglass tunnel could have been a similar sort of situation at around the same time?
Don't know if that helps!
