Rx8/AJ30 project parts for sale
Rx8 shell.
Shell: stripped out rolling shell, has weld in roll cage made but not finally welded in, lowered front x member for engine space, perspex windows,
roof vent, tein adjustable suspension all round, low ratio lsd axle, aluminium baffled race tank, low pressure and high pressure pumps, swirl tank,
wired and piped through to engine bay, bonnet and boot catches fitted. V5 in my name.
Was well known track car. £500:00
Engine: standard aj30, fitted with baffled and gated sump, st 220 manifold with modified lower inlet manifolds to give engine bay space. £250
St220 inlet man baked silver paint. £50
rx8 gearbox with lever, modified, has 10mm taken off bell housing to accommodate spacer plate,£300:00
Rx8 gearbox, standard £250
Aj30 spacer plate 10mm £75
centre push clutch release mechanism, (new, unused). £75
Carbon fibre prop. £25
Corsa pas column, £25
New ms 2 megasquirt, complete with coil drivers, unused or fitted, has map for standard Aj30 engine fitted with lowered vvt cut off (5k) for top end
power. £300:00
New unused or fitted bespoke engine loom to fit Aj30 made by shaun at extra efi, £200:00
Rx8 rims, good road tyres. £100
Rx8 bonnet, boot and bumpers. Various prices
2 OMP first r seats, I brand new never fitted, 1 as new, perfect. (out of date for rallying)£300
I don't know how to put pics on here, but I can email pics if interested.
situated in bangor north wales, but could deliver ??
Email: mike1.hammond@hotmail.co.uk
mob: 075087391156
mike
[Edited on 28/4/23 by MootchA]
