Wheels244
| posted on 11/7/23 at 05:48 PM |
Manual 4 Post Car Lift
Would anyone be interested in my Manual 4 Post Car Lift ?
Has had my Locost sat on it for (too) many years.
The person I bought it from stored an E- Type Jag on it.
It is VERY solid and rather heavy.
Really useful for storage of a vehicle, can get another underneath it, depending on size.
Only reason I’m selling is I’ve been offered a single post lift from a friend.
It’s ideal for garages without power.
I’ve added brackets to allow the track width to be adjustable.
It lifts and lowers using 2 manual winches.
I was thinking about £250 - it must be worth that in scrap value.
I can either remove it ready for collection, of if someone wants it, I could dismantle it with them so they can see how it goes together, although it
is quite explanatory.
Any question, feel free to ask.
  Lift 1
  Lift 2
  Lift 3
  Lift 4
  Lift 5
  Lift 6
Build Blog: http://wheels244.wordpress.com/
roadrunner
| posted on 12/7/23 at 05:51 AM |
If only I had a bigger garage
Slimy38
| posted on 12/7/23 at 07:30 AM |
Same, by the looks of it I'd need an extra couple of feet height and probably the same again on the length. Considering there's a bedroom
above the garage I doubt my missus will want me knocking through the ceiling.
adampage
posted on 12/7/23 at 01:47 PM |
Interesting....
Hey, can i ask a few questions about this one?
- What are the outside sizes? And length of longest individual part (assume wheel tracks)?
- What failsafes are there when it's winched up, any lockouts or props etc?
- How high can it winch the platform up to?
- Idea of max load in kg? Assume Locost is no problem, but what about mini / mx5 / etc?
- Is it in Yorkshire to pick up?
- Is it homebuilt or from a kit / manufacturer?
Ad
Wheels244
| posted on 12/7/23 at 07:15 PM |
Hi Ad
Please see the responses against your questions below.
Width of the uprights = 2540 + 75 either side for the floor pads. The track width is currently 1840, but can be narrowed by up to 280 due the brackets
I’ve added and adjustable for any width between. The overall length of the tracks is 3880.
The uprights have holes drilled in all four legs. I use 4x20mm bolts as pins and lower the lifting part onto them so they take the full weight and
there’s no load left on the winches. They won’t be shearing anytime soon.
- How high can it winch the platform up to ?
The underneath of the horizontal beam that you can see in the pics measures 1415 from the floor - this could be increased by drilling more holes in
the uprights and adjusting the turnbuckles.
No idea to be honest, it’s definitely had an E- Type on it, obviously my Locost - I’m positive there wouldn’t be any issue with a Mini or an MX5. I’m
sure the steelwork could easily manage a Transit van ! But I think the limiting factor would be the winches.
Yes, I’m near Bedale, North Yorkshire.
(There is a limited potential for delivery)
I think it was commissioned by the E Type owner. It’s been well made, but I would suggest it’s been made in a Fab Shop somewhere. To manage
expectations, it’s robust - but you won’t find any LOLER compliance certificates or testing - if that’s what you’re looking for, this probably isn’t
for you.
Ad
Happy to supply any more info required.
I’m away with work shortly, it won’t actually be available until the end of August.
adampage
| posted on 12/7/23 at 08:20 PM |
Thanks!
Awesome, thanks for that, really helpful.
Let me have a measure up and a think, I’ll let you know, but if anyone else goes for it quickly then no worries
Ad
wrayvon
| posted on 14/7/23 at 09:29 AM |
If only I had a wider/longer/higher garage!
Sanzomat
| posted on 18/7/23 at 05:03 PM |
I'm quite interested in this as a possible solution to store my Locost above my GTM. Looking at the dimensions you gave earlier it seems the
width including the baseplates is 2690. My garage is 2700 wide so a bit tight but might just work!! I note from the images however that the hand
winches are outside the uprights and appear to be wider than the baseplates? Could the winches work turned through 90 degrees so to be on the front or
back rather than the side of the upright?
What is the height of the uprights?
My other query would be regarding the total weight. I have a car transporter trailer with a payload of 1125kg. My wheel beds are only 3350 long so
your tracks at 3880 would overhang but evened out that is only a 265mm overhang each end so should be okay length wise. I'm wondering if it could
all go on the trailer. Only 250 miles each way!!!
Wheels244
| posted on 22/7/23 at 08:49 PM |
Apologies - just seen the post, I’m working away at the moment.
I’d have to check your queries when I get home.
I ‘think’ it would be possible to mount the winches at 90 degrees, but would need to check. The crossbeams could be cut and rewelded to reduce the
width if required.
I’ll measure the uprights when I get home.
I don’t think you’d have any problem loading it onto a car transporter trailer - I borrowed a friends twin axle builders trailer when I bought it.
Wheels244
| posted on 17/10/23 at 08:39 PM |
Last call for the lift before I either repurpose it, or weigh it in for scrap.
I’ll be taking it out a week on Wednesday to fit the single post.
Wheels244
| posted on 15/11/23 at 04:34 PM |
Sold
