Slimy38
posted on 14/11/23 at 09:16 PM |
Fog light for my car
I'm after some ideas... here's my rear end;
The smaller hole halfway up is 45mm, then I have two gaps for 70mm lamps. But I can't find an e marked fog lamp that would fit in either. Is
there any other option for adding an appropriate fog light?
[Edited on 14-11-23 by Slimy38]
gremlin1234
posted on 14/11/23 at 09:44 PM |
could you fit it on the roll bar?
Slimy38
posted on 14/11/23 at 10:26 PM |
Would that pass IVA?
gremlin1234
posted on 14/11/23 at 10:45 PM |
I just checked, only if it is below 1metre, (or 1.2m if you mount the other lights there too.)
Slimy38
posted on 14/11/23 at 11:02 PM |
Hmm, I could mount it on a vertical section. The cross bar is definitely above 1 metre. I just need to make sure I maintain the 5 degree down angle by
not putting it too low on the vertical.
Mr Whippy
posted on 15/11/23 at 07:42 AM |
The real question is how do you get to your car?
Slimy38
posted on 15/11/23 at 08:09 AM |
From underneath!
There's an engine, suspension and all manner of parts just round the corner behind the welder, once they're actually on the car there's
a surprising amount of room. It's that same problem that haunts all kit car builders, the fact that a donor car takes up so much more space as a
bundle of parts than it ever did as a full car.
posted on 16/11/23 at 10:50 AM |
The 70mm lamps - do they not do these with a built in fog light (at least to one side)?
Slimy38
posted on 16/11/23 at 11:30 AM |
Not with the required marks, that's what I'm struggling with. Take the Defender 90 as an example, replacement light sets for a 90 consist of
70mm lights for side, brake and indicator so they would work perfectly. But the reverse and fog light are 90mm.
I found one fog light that was 50mm, but while it had an E mark it didn't have the other one (A 'B' I think it needs?).
posted on 16/11/23 at 01:27 PM |
Fair enough - I figured you'd probably have checked.
Different car and SVA not IVA when I did mine, but IIRC it only required an "E" mark.
Slimy38
posted on 16/11/23 at 02:06 PM |
Aye, those square ones are quite common and available with the two marks. I was thinking of putting one underneath the curve of the body, a bit like
they do with Japanese import cars. But it would be better if it was part of the standard light set up.
For the amount of time I predict driving in fog (IE never!!) I'll probably switch it out for an unmarked fog light after IVA. As long as
it's good enough for the MOT then I'm happy.
posted on 16/11/23 at 04:11 PM |
Likewise - in the 3 years I drove my Indy before selling up, I don't recall ever driving in fog. It was a means of getting through the SVA test.
Schrodinger
posted on 18/11/23 at 10:43 AM |
https://www.carbuilder.com/uk/55mm-led-fog-light
This any use?
And have you checked the manual, do they have to be E marked ?
[Edited on 1 by Schrodinger]
Keith
Slimy38
posted on 18/11/23 at 11:30 AM |
This any use?
Aye that's the one I found (I remembered it as 50mm but that's the one I saw). This is from the IVA manual;
All rear fog lamps must display an "e" or "E" mark with a "B" or "F"
Schrodinger
posted on 18/11/23 at 11:41 AM |
Just looking at the photo that is E marked but check with CBS.
Keith
gremlin1234
posted on 18/11/23 at 05:12 PM |
yes it appears to be E and F marked
