<<  1    2  >>
Author: Subject: I'm fitting solar panels soon
posted on 1/1/24 at 07:27 PM Reply With Quote
They are getting crazy cheap these days. So cheap that I'm going to ditch the feed in tariff and fit it myself. I think it would be about 7k more to get a registered installer in. Here what I'm thinking of getting:
10x 425w panel at £99 each
2x 5.5kw inverters @ £690 each (conversol v7 from voltacon solar)
15kwh lithium battery from fogstar.com for £2.5k - crazy how cheap they've got.
That set up can also handle an extra ten panels on the other face of the roof, which I'll fit at tree end of the year to help meet winter supply.
Under 5k to cover nearly all the electric I use, with enough spare in summer to cover hot water too.
Anyone end plotting diy solar?
posted on 1/1/24 at 07:29 PM Reply With Quote
https://www.fogstar.co.uk/products/fogstar-energy-15-5kwh-48v-battery?pr_prod_strat=e5_desc&pr_rec_id=3af41eec6&pr_rec_pid=7214460665915&p r_ref_pid=7082856087611&pr_seq=uniform
Slimy38
posted on 1/1/24 at 09:19 PM Reply With Quote
I have to be honest, that 7K gives a whole lot of peace of mind. I really wouldn't know what would worry me more, setting up my own scaffolding so I could drill holes in my roof and get these whacking great panels fitted and working without causing structural damage. Or knowing how to work with electrickery to a level where the electric company would be ok me hooking up some extra currents to their meter.
That's just on the installation too, when I go for mine I'd want to know that for 10 years I could just phone up an installer and get them to come take a look at any issues, leaks, power loss etc.
I like the idea of prices finally coming down, a quick Google for 15kwh batteries just shows that 2.5K is a fraction of typical market prices.
craig1410
posted on 2/1/24 at 02:54 AM Reply With Quote
Hi JoelP,
I fitted my own solar PV and battery system last year and it has worked out great so far. Long story short I have 16 x 425W (6.8kWp) PV array made up of Trina Vertex S 425W panels on my garage roof. They are coupled with a Victron Multiplus-II 48/5000/70-50 hybrid inverter via two 250/60 MPPT smart solar charge controllers. The batteries are three US5000 modules from Pylontech and the have so far been flawless. Total capacity is 14.4kWh (13.68kWh usable).
I live in Scotland and so the rules around electrical installations are a bit different domestically. There is no part-p and in my situation I can basically do my own installation as long as I do it to BS7671 standards. I have the various regs, equipment and a degree in electrical engineering so am pretty confident I can do just that.
That all said, you really must get G99 approval for your installation BEFORE you commission your system. Otherwise potentially your DNO (Distribution Network Operator) can disconnect your supply. It's not that hard to complete your own application for G99 but if you want to get some help then I would recommend https://g59projects.co.uk
G99 approval is a lot easier than it was when I started so don't be intimidated.
I've heard of fogstar and it's really nice to hear about UK based battery suppliers but I can't vouch for them since I have no experience of them. Same for the inverters you mention. All I would say is to ensure by whatever means necessary that you maximise safety because high voltage DC is even more dangerous than high voltage AC so you need to be very sure of the quality and integrity of your connections. Any bad connections can easily start fires so don't scrimp on electrical safety.
My installation cost about £10k but would be around £7k today and despite NOT having MCS certification, I managed to get an export MPAN and tariff from Octopus Energy, So I now get 15p/kWh from Octopus and have made over £80 this winter alone from the "Saving Sessions" that Octopus have been running on behalf of the national grid. My primary aim was always self-consumption but in the summer I have more power than I can use to it's nice to send the excess back to the grid.
So, yeah I think DIY solar is very much viable and increasingly attractive. Just make sure you either have the required skills and knowledge yourself or bring in someone who has. They definitely DON'T need to be "MCS certified" in order to get an export tariff although Octopus do charge £250 for non MCS approved installations.
If you do decide to switch to Octopus then if you use this link then we'll each receive £50: https://share.octopus.energy/bold-foal-39
Let me know if you have any questions.
ps. I suspect @Slimy38 is an MCS installer.
Benzine
posted on 2/1/24 at 07:58 AM Reply With Quote
Good thread! Something I've thought about quite often. The area I live in has become a conservation area though, so I'm not sure if that makes things more difficult.
Slimy38
posted on 2/1/24 at 09:17 AM Reply With Quote
LOL, not even close! I've not approached any solar power stuff yet, I'm thinking about it as the next major house project but that's about it. However I did work on telephone exchanges when I was doing my apprenticeship, and seeing a spanner literally evaporate when accidentally connected across a battery pack, I'm all too aware of the dangers of high voltage DC.
That work was also covered by BS7671 albeit the 16th edition. From memory the regs are mainly common sense stuff, with a few tables to cross reference for connector/cable sizes etc. A bit like the IVA manual for building a car? Buying a copy of the regs used to be very expensive, but I've just checked and it's just over £100 which is actually quite reasonable now.
As with any DIY project if you have the confidence in your abilities and at least some knowledge in the regulations and standards then I encourage doing it, I personally think it's outside my skillset. My wife is still complaining about the soffits that need fixing, so I doubt she'll be letting me install my own solar!!
roadrunner
posted on 2/1/24 at 10:08 AM Reply With Quote
Hi Joel.
I purchased a 6kw DIY kit at the beginning of 2022 and installed it myself. Didn't get the batteries though, to expensive at the time.
It was really easy to fit, except for the height and working from a tower scaffold.
Even though it's classed as a DIY kit, it is exactly the same as set up as the Pro's install.
My best mate is an electrician and he did the technical bit wiring up to the consumer.
It's been one of the best addons I have done to the house.
russbost
posted on 2/1/24 at 11:38 AM Reply With Quote
I'm interested to hear what people have done with regard to get their kit signed off for G98 or G99, I've installed a load of solar & batteries myself, but have kept it all off grid.
Been looking at helping my son in law with a fresh install from a DIY kit for his place, but I've spoken to 3 sparkies I know personally & have put a considerable amount of work through in the past & they are all saying they aren't qualified to sign off a solar installation, that it requires specific training/accreditation
I know someone who's installed an 8kW setup & simply not told the DNO, all very well unless something goes wrong, at which point I think expensive litigation might start flying around
I've looked at doing a G98 install ourselves as you actually commission the system b4 you get it signed off (which seems pretty bizarre to me!) - when you look at the form, it asks for the qualification of whoever is signing off & also asks what accreditation they have - whether anyone ever actually looks at what's on the form or checks anything again I have no idea, but if you put anything falsified on there & it then did go wrong, the outcome is not gonna be good
Any personal experience or anyone on here capable (& happy to!) check over & authorise an installation I'd be interested in any info
russbost
posted on 2/1/24 at 11:40 AM Reply With Quote
Also @JoelP, where have you found 425W panels for £99 ea, sounds a lot cheaper than what I've seen?
roadrunner
posted on 2/1/24 at 12:24 PM Reply With Quote
Getting mine signed off by the DNO was a bit of a surprise and expensive.
When I researched DIY fitting, nothing came up about the sign off and how expensive it might be.
If I'd stuck with a standard 3.8kw system it would have been free. But because mine was a 6kw set up the DNO have to check that the local grid can cope with over amping. It can take up to 4 months. Unfortunately for the DNO, when I realized and contacted them I already had the system up and running, so they pushed it through. It cost me another £400.
I had my install checked by the supplier of my kit, and because the electrical side had been signed off I got the MCS cert for another £400.
I have received just over a £1000 back from Octopus in the last year alone. Another year or two will see the panels pay for them selves.
The 6kw kit cost me £3600.
posted on 2/1/24 at 01:40 PM Reply With Quote
Hi all. Thanks for the input, much appreciated. I didn't actually know it was possible to register for feed in payments on a DIY install. I was just going to use offgrid inverters and not bother sending any back, therefore also not telling the dno. I'm a qualified electrician, plus I put the roof on my house myself, so I guess I'm in a lucky position there!
I'll dig out a link for the panels now...
posted on 2/1/24 at 01:43 PM Reply With Quote
It's a preorder for next month. Bifacial though, so even higher output if any light hits the back side, ie on a frame in the garden.
https://voltaconsolar.com/solar-panel/et-solar-panel-430w-bifacial-monocrystalline-half-cut.html
I should add that there's loads of panels at the £120-£130 mark. Prices are collapsing faster than you can keep up with.
[Edited on 2/1/24 by JoelP]
coyoteboy
posted on 2/1/24 at 10:36 PM Reply With Quote
@Craig, that's interesting to hear, every supplier I checked including octopus said mcs was an absolute requirement and they wanted the cert number.
russbost
posted on 3/1/24 at 10:37 AM Reply With Quote
That's my understanding too, I'd be interested to see anything in writing from Octopus or anyone else regarding a non MCS install - a charge of £250 would be a LOT less than the difference between an MCS/non MCS install at purchase
Mr Whippy
posted on 3/1/24 at 01:10 PM Reply With Quote
That looks a great price.
If the panel is facing East or West is it going to make a huge difference to the power output?? It's just my garage is ideal with a 50sqm area apart from not facing south! However its not impossible to rotate it as the garage is 6 x 6m and I built it in the first place but it's a bit of a pain.
posted on 3/1/24 at 03:59 PM Reply With Quote
Flat or pitch roof? I'd just pick whichever pitch is best, or if flat, just cover it with flat panels. Better flat than on frames and casting shadows on each other.
Mr Whippy
posted on 3/1/24 at 08:48 PM Reply With Quote
sorry it's a 20 deg pitch with the gable facing south, a great simple roof but not really the best origination the house does face the sun but has dormers in the way.
craig1410
posted on 3/1/24 at 10:47 PM Reply With Quote
If you want good value PV panels, check out https://midsummerwholesale.co.uk/buy/trina/trina-425w
These are the panels that I bought in summer 2023 and they cost me twice that price at the time. I'm seriously considering buying another 16 to put on my north facing roof because they are so cheap now!.
Another company I would recommend is https://essandsolarsolutions.co.uk who I bought all my Victron gear from. In fact I also bought my solar panels from this company since they can get a bit of a trade discount from midsummer. The owner is called Etienne and he is a really nice guy and very knowledgable. He will sell you a complete DIY solar/battery system if you want one, and will give you good advice on how to get it set up.
The G99 process isn't something you need to be intimidated by, especially for a typical domestic installation, as long as the equipment you are installing is type tested on the ENA database here ( https://www.ena-eng.org/gen-ttr/ ). Have a look at this guidance document for more details. Search for SGI-3 as that is most relevant for G99 installations: ( https://connections.nationalgrid.co.uk/downloads/24747 )
I have heard of several people getting G99 approval the same day they applied for it. For me it took longer but mostly because the fast track process was more restrictive when I started AND my hybrid inverter was going through some type testing issues. Once resolved it was approved no problem. I initially had to pay a £300 "design charge" to SP Energy Networks but this was later refunded as it had been charged in error.
Another forum thread worth reading is this one: https://community.victronenergy.com/questions/131033/uk-ess-self-install-mcs-certification.html and https://community.victronenergy.com/questions/225189/now-open-to-all-no-more-mcs-needed.html
I'm on that forum as "Craig Chamberlain" and you will see a number of my posts as the whole Octopus non-MCS trial process kicked off. I was told by a senior Octopus field engineer that I was the "first" trial customer for non MCS installations. Unfortunately, Octopus rolled back a little bit after my installation was approved and introduced the £250 fee and now require some evidence of electrical installation and building control authorisation. But if you follow "solar sam" on the above thread you'll see that Octopus will give you an export tariff if you follow the non-MCS process.
@Slimey38 - sorry if I got you wrong but it just sounded like you were actively discouraging DIY installations. I see from your last post that this is not the case.
If anyone has any questions then please feel free to DM me or reply in this thread.
coyoteboy
posted on 4/1/24 at 12:00 PM Reply With Quote
Some good info there Craig, thanks! I've been planning a DIY install for a long time but thwarted by the MCS nonsense. My god, those panel prices are so cheap! I have a 400W setup on my garage roof feeding batteries, the panels for that cost four times that $/Watt about 4 years ago.
Are you a qualified electrician or did you get it inspected?
Trying to find a list of the requirements is not easy. The G98/99/100 process is fairly clear but building regs requirements are less so (of course structural reqs are obvious, but there's no list of electrical requirements to follow such that you'd know an electrician would be happy to sign it off). In England I guess you'd follow Part P but in Scotland maybe that's guidance only? This is part of the problem with the MCR scheme - the info is quite thoroughly hidden by gate-keepers under the "just use an MCS accredited person". I should spen an evening digging further.
[Edited on 4/1/2024 by coyoteboy]
Mr Whippy
posted on 4/1/24 at 12:34 PM Reply With Quote
tbh at those process I don't think I care if the garage is facing south...
SteveWalker
posted on 4/1/24 at 11:01 PM Reply With Quote
ISTR reading that while South generates the most power, West provides the most power at times of peak need. The overall difference is West having 80% of the output of South, but at a better time.
Mr Whippy
posted on 5/1/24 at 07:21 AM Reply With Quote
Thanks, that may be more useful as I don't intend on any battery storage (for now), just feeding back the excess to the grid to reduce the overall bill. In summer that will power more than I need for the whole house easily. Need to look into exactly what is required.
craig1410
posted on 5/1/24 at 11:59 PM Reply With Quote
Yeah PV panels prices have dropped considerably even since I bought mine. I think I paid something like £175 a panel inc VAT back in May 2023 and those exact same panels are now £92 each inc VAT.
I’m not an electrician although I do have a degree in Electronics & Electrical Engineering so I understand “electricity” pretty well and have many years experience of doing electrical jobs around my various houses over the years. The scope of what you need to know in a relatively modern house is massively reduced compared to what you would need to know as a commercial electrician dealing with domestic and industrial installations. That said, I take it very seriously and do a lot of reading and watch a lot of YT videos before I’m happy to proceed. I bought a copy of the 18th edition regs and on-site guide and a bunch of other specialised books on ESS systems and have read them thoroughly. I also have a Megger multi function tester and torque screwdriver and a bunch of other tools and equipment that are really needed to do a proper job. So, as a result, I feel as if, as long as stay within my “comfort zone” in terms of scope, and take all the time I need to read, research and complete each job including all the testing, then I can consider myself competent. I’ve no doubt that a really good electrician could do a better job but I also know that there are plenty of cowboy electricians out there who would do a considerably worse job than me. I’ll probably get an EICR done just as a means to have a second pair of eyes look over at least the AC side of my system.
We don’t have part p in Scotland and as long as you’re not working in building with more than ground and first floor, or a commercial building or some other exclusions, then the scottish building control website says that you can pretty much do whatever electrical work you want. This is just my view from reading the website though so this should not be taken as advice. If in doubt then talk to your local building control officer.
My PV panels are installed on a refurbished agricultural outbuilding roof and as part of that refurb, we replaced the fibre-cement/asbestos roofing sheets with kingspan quadcore 80mm insulated panels. We also replaced all the timber purlins with new C24 graded purlins which were 25mm deeper (9” instead of 8”). Comparing the weight of the old fibre-cement with the new insulated panels they are both stronger and lighter, and even with the solar PV panels added, the roof loads are less than they were before. Since it’s an agricultural building, I don’t believe building control have any interest in it anyway. If I had been installing the array on our house then I would definitely have got more advice in this area but I’m sure it would have been fine as it was only built around 16 years ago.
In terms of electrical sign off, until relatively recently I think you only needed a new circuit installed for the inverter and then the inverter was treated as an “appliance”. But in recent years BS7671 has started to cover more and more of the renewables stuff that previously only MCS covered. That’s why in my opinion, MCS has had its time and is no longer necessary. Also, by removing MCS, it opens the door to hundreds of really good, independent electricians who otherwise just can’t afford the bureaucracy of MCS accreditation.
HTH - sorry for the long post.
craig1410
posted on 6/1/24 at 12:34 AM Reply With Quote
I hear what you’re saying and in cases where the occupants don’t adjust behaviour then it might be broadly true. However, I think a lot of people are able and willing to make adjustments to consumption patterns to maximise use of renewables. Even simple things like using the timer on your dishwasher or washing machine etc. Also, it’s more common these days for at least one occupant to work from home which changes usage patterns and provides opportunities for further flexibility.
But the real game changer is of course to incorporate battery storage which then allows you the greatest flexibility and reduces the need to adjust behaviour in many cases. This is especially so in late autumn through to early spring when the sun doesn’t get high enough in the sky for meaningful generation unless the roof is south facing.
Today was a really nice sunny day in west central Scotland and our 6.8kWp array peaked at 2350W around 12pm and produced in excess of 1kW from 10am to 2:30pm. That’s pretty much as good as it gets at this latitude on a south facing 15 degree roof. Total generation today was 8.6kWh. If my roof had been west facing I doubt I would have got even half that generation.
posted on 7/1/24 at 05:49 PM Reply With Quote
I fitted house batteries just over 12 months ago - a major difference! Mine charge overnight using Octopus Go (which I have for our cars) so, most of the time, we run appliances during the day at off-peak rates (less than 1/3 cost per unit). In sunnier months we don't take much energy overnight as PV tops it up all day so little is required to get back to 100%. In these months we also charge our cars during the day - and we get paid for all electricity that comes off the roof (under an old solar payment scheme) so we get paid to charge the house and car batteries! No longer possible under current schemes though...
It's nice to sit watching TV in the evening, seeing the total house grid load on the smart meter display varying between 0 and 100W most of the time (usually near 0W).
But I won't open the debate whether house batteries are economic if you include the installation cost... still not cheap to fit.
<<  1    2  >>
