Author: Subject: Hispec rear callipers, Ford fit
Twobeers
posted on 15/2/24 at 12:20 AM Reply With Quote
Used for around 10 hours (6 race weekends) in a Ginetta G20.
These are as the link below, Ultralite 2 (UL2 FREAR) anodised black and are designed as a direct replacement for standard Ford Sierra rear hubs, ie, 2 lugs.
I've gone to a completely different rear disc set up and have replaced these with the same but in a radial mount pattern. Hispec weren't the easiest to deal with but to be fair we've never had a problem with their products. 200.
http://www.hispeccalipers.co.uk/ultralite-2.html
I also have a set of alloy hubs to take 273mm discs (not the standard 253mm) so slightly longer ears. Complete with bearings and seals and used for one race weekend. Also, a pair of 273mm discs to suit these, again used for 3 track sessions. Gone to a different set up so no longer required. 150 for the hubs, 40 for the discs.
wowblaauw
posted on 17/2/24 at 11:51 AM Reply With Quote
Hi, I'm interested in this whole setup. Where are you based?
"Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well preserved body, but rather to skid in sideways, chocolate in one hand, wine in the other, body thoroughly used up, totally worn out and screaming...
Damn, What a ride!!"
Twobeers
posted on 17/2/24 at 06:54 PM Reply With Quote
Hi, I'm based in Chipstead, Surrey. For clarification and in response to another enquiry, these are without hand brake mechanisms.
wowblaauw
posted on 17/2/24 at 07:20 PM Reply With Quote
Ok and thanks, I'll be giving these a miss - good luck with the sale
roadrunner
posted on 19/2/24 at 10:01 AM Reply With Quote
Hi.
Is there a way to fit handbrake with theses calipers.
Brad
Twobeers
posted on 19/2/24 at 12:14 PM Reply With Quote
No, the version with the handbrake option is completely different, this version is purely a caliper. Hispec do a separate handbrake only system if that's any help.
roadrunner
posted on 19/2/24 at 03:34 PM Reply With Quote
frodo_monkey
posted on 28/3/24 at 10:25 PM Reply With Quote
Are these still available?
"Racing is life. Anything before or after is just waiting."
Twobeers
posted on 28/3/24 at 11:47 PM Reply With Quote
Yep, still available.
frodo_monkey
posted on 29/3/24 at 01:28 PM Reply With Quote
u2u sent!
Twobeers
posted on 2/4/24 at 03:36 PM Reply With Quote
Calipers sold, hubs and discs still available
wrayvon
posted on 3/4/24 at 08:13 AM Reply With Quote
Not wanting to take over the thread but if anyone else was after some calipers I also have a set. Feel free to PM me.
