scudderfish
posted on 23/3/24 at 03:54 PM |
Fighting with a fuel tank in a Fury
Years ago I bought a bigger tank made for a Fury from someone on here. I've finally got around to fitting it. My car has an Atlas rear axle,
and whilst the tank will fit when it's in, it's fouling on the diff getting it in.
I'd like to not have to drop the axle and hopefully get away with just removing the rear cover. Any idea if there is much clearance between the
inside of the cover and the crown wheel? If I'm only going to gain 2mm it's not worth draining the diff and I'll have to drop the
axle.
![](https://dgs.prose.sh/foul.jpg)
adithorp
posted on 24/3/24 at 11:13 AM |
It might squeeze out with the cover off but I doubt it. Pretty sure the crown wheel protrudes something like 1/2 as far as the cover.
A lot of people cut a section of the rear panel to be able to get the tank out and then make a cover the secure over it.
http://jpsc.org.uk/forum/
scudderfish
posted on 24/3/24 at 03:05 PM |
Cutting the bodywork is not something I want to do. Daughter's BF is coming over next weekend so I'll rope him in and drop the axle.
jacko
posted on 24/3/24 at 08:30 PM |
Rubber mallet and modify the tank to miss the diff
Even if you drop the axle dose it not go up and down in driving
555
Mr Whippy
posted on 25/3/24 at 04:15 PM |
Looking at your springs you still have heaps of travel left so your going to have to take a big notch out the tank.
scudderfish
posted on 25/3/24 at 05:51 PM |
The tank will fit without hitting the diff, once it is in place. Right now my struggle is manoevering it into place. It needs to go in at an angle
and then rotate unless I take a saw to the bodywork.
jacko
posted on 26/3/24 at 02:37 PM |
If you think it will fit by lowering the axle that seams the way to do it 👍😀
Graham
555
scudderfish
posted on 29/3/24 at 05:44 PM |
It's in!
![](/galpreviews/IMG_20240329_172501981.jpg) ![It is in](/gallery/IMG_20240329_172501981.jpg) It is in
![](/galpreviews/IMG_20240329_172544920_HDR.jpg) ![Other view](/gallery/IMG_20240329_172544920_HDR.jpg) Other view
(the forum doesn't appear to honour rotation EXIF info )
We (daughter's BF and I) undid the panhard rod and detached the shocks that enabled us to drop the axle by about 3-4 inches without disconnecting
the prop of brake pipe. Heaved it in to find the filler pipe wasn't going through the hole in the boot floor. Tank out, apply violence and
power tools to boot floor and then it fit in
Feeling knackered now though.
jacko
posted on 29/3/24 at 05:56 PM |
Where there’s a will there is a way
Well done to you both
555
