New Topic New Reply
Author: Subject: The rubber trim from P clips
jps
posted on 29/3/24 at 09:50 AM Reply With Quote
I’m after some rubber trim, the same profile as is fitted to the rubber lined/steel P clips, I.e. it wraps around a strip of metal on both edges
No idea what to search for on eBay etc though, I just get lots of the standard ‘single sided’ U trim.
Any ideas?
jacko
posted on 29/3/24 at 03:36 PM Reply With Quote
I cant help with the rubber trim but can you slide heat shrink over the metal and shrink it on
Graham
555
jacko
posted on 29/3/24 at 03:50 PM Reply With Quote
Look up hose clip protective sleeve
555
ianhurley20
posted on 29/3/24 at 04:56 PM Reply With Quote
Have a look on the Woolies web site https://www.woolies-trim.co.uk/ they seem to have most types of trim
cliftyhanger
posted on 29/3/24 at 05:50 PM Reply With Quote
Or even a thin wall bit of plastic hose?
If using heat shrink, 2-3 layers would be best to give protection.
New Topic New Reply
