Author: Subject: leaking MT75 Gearbox
axle
posted on 12/4/24 at 11:05 AM Reply With Quote
Hi all
I wonder if anyone has experienced the above matter. I see small amount of oil leakage from MT75 gear box the car has been off the road for the last few month . The leak seems to be coming at the rear top around gear selector. Sorry can not be more accurate as the view is a bit restricted.
Regards Axle
IVA passed 1st time thanks to the Forum members.
Mr Whippy
posted on 12/4/24 at 12:04 PM Reply With Quote
Have you check the breather hole or pipe? if blocked and the gearbox heats up, the expanded air pushes oil out past the seals or anywhere it can.
here you go -
[Edited on 12/4/24 by Mr Whippy]
axle
posted on 13/4/24 at 07:29 AM Reply With Quote
Thanks for your reply , I shall.
Regards Axle
