posted on 4/6/24 at 07:21 PM |
Brake fluid leak
Evening again. I've noticed my brake fluid is dropping onto my exhaust. It appears to be leaking from where the plastic reservoir joins the metal
master cylinder. Any idea what causes it, and indeed what donor car this is from? Quite rare I believe, the fact that I've got the servo too.
Photos in following post cos I forgot to upload first!
posted on 4/6/24 at 07:23 PM |
  Locost master and servo
posted on 4/6/24 at 07:24 PM |
Leak just visible. It drips until empty.
  The leak
posted on 4/6/24 at 07:31 PM |
I think it's from a Sierra. I can only see 3 brake pipes though. Will there be a 4th outlet plugged? It's back under its tarp now.
cliftyhanger
posted on 4/6/24 at 07:36 PM |
The resevoirs are usually a push fit with some rubber seals. So they may have called it a day, or a crack in the resevoir.
Take care as brake fluid is highly flammable, worse than petrol.
posted on 4/6/24 at 07:39 PM |
Thanks, I didn't know that! It's smoked loads as it burnt it off!
adithorp
posted on 4/6/24 at 08:58 PM |
Yes, you deginatly don't want it dripping on a hot exhaust. Pretty low flash point. The zip tie is to stop it coming off in a shunt and causing
a fire.
I guess it'll either be a perished rubber seal or maybe corrosion between seal and master or a cracked reservoir.
http://jpsc.org.uk/forum/
jps
posted on 5/6/24 at 09:45 AM |
Doesn't look exactly the same as my Sierra brake res (which looks like this:
But there may be different versions over the years of production?
[Edited on 5/6/24 by jps]
gremlin1234
posted on 5/6/24 at 12:31 PM |
apparently the mounting seals come with a master cylinder repair kit. item 6 in the pic below
https://ford.7zap.com/en/car/63/6.46050,13.35344/0/1888/16875/73219/
posted on 5/6/24 at 12:35 PM |
Looks very similar to my Sierra brake setup
Individual ports for each front brake and a single port to the rear that was then "T" split to the rear wheels.
posted on 5/6/24 at 02:37 PM |
Thanks everyone! I'm pretty sure mine is plumbed differently to yours Nick. Rear brakes connected to front top outlet. Should this be rectified?!
posted on 5/6/24 at 03:25 PM |
Can't advise if you should change the way yours is plumbed in.
From memory I plumbed mine as it was in the donor Sierra before I removed it.
Also from memory (not in the image) I added a rerar brake valve limiter (from a Fiat Uno) in the rear brake line. Purpose was to prevent rear wheels
locking up before the front wheels.
The car passed it's SVA and subsequent MOTs with this setup.
[Edited on 5-6-24 by nick205]
SteveWalker
posted on 5/6/24 at 09:54 PM |
There was a similar valve on the Sierra, that's the one I used.
SteveWalker
posted on 5/6/24 at 09:57 PM |
Very likely. Certainly mine is exactly the same as the OP's picture, although the master-cylinder is different, with that one looking very smooth
and almost like a fabrication from tube, while mine is much rougher and much more obviously a casting.
adithorp
posted on 6/6/24 at 09:45 AM |
Ford swapped from cast to fabricated brake masters sometime towards the end of Sierra production.
posted on 6/6/24 at 12:37 PM |
My donor Sierra was a G plate Sierra Saphire saloon (MOT failure due to rotten floor)
posted on 13/6/24 at 03:20 PM |
Thanks everyone. I ordered the seal kit off eBay, swapped the two big ones, and it appears to be fixed. Went for a spin to burn the spillage off, and
got caught in torrential spitting. Well, it felt torrential at 60 with no wipers
