Author: Subject: IVA compliant bezels for Smiths instruments
Mike Wood
posted on 9/6/24 at 10:45 AM Reply With Quote
Hi
Does anyone please know of a source of IVA compliant round edged replacement bezels for Smiths instruments including 4 inch diameter? (MG Midget rev counter and speeedo). Often still known as SVA bezels. I can find 52mm ones at Merlin Motorsport and Europa to go with Smiths gauges for Cobra replicas but not other sizes (see Merlin Motorsport: https://www.merlinmotorsport.co.uk/p/smiths-clip-on-bezel-for-52mm-classic-gauges-cb-bez-52, https://www.merlinmotorsport.co.uk/s?search=Bezel & https://www.europaspares.com/smiths_spare_bezel_round_52mm_chome_scbr52).
I canít find anything on the website of the manufacturer of Smiths instruments (Caerbont Automotive) but might try ringing them to ask.
I realise that I could put the instruments behind the wheel with their non-compliant bezel section or recess them into a padded dashboard; I do not have a 3d printer to make something - I suppose a bit of cut down glued on black wiring insulation might work from the outside of an old bit of 13 amp cable (kettle lead).
Mike
[Edited on 9/6/24 by Mike Wood]
HowardB
posted on 9/6/24 at 06:22 PM Reply With Quote
You could put them in the shadow of the steering wheel
Even if just for IVA?
Howard
christim
posted on 9/6/24 at 10:27 PM Reply With Quote
I have the same problem...done a lot of searching but no-one seems to have the larger round bezels. I don't think they exist, which is odd as they make them for the 52mm gauges as you say.
Best approach I think is to just cover them with something for the test as you suggest. (I have 3d printed some bezels for my 80mm gauges...they're ugly but will get it through the test)
My Build Thread
Slimy38
posted on 10/6/24 at 07:14 AM Reply With Quote
Apologies for hijacking the post, do you have some pictures of your 3D printed bezels? I will be doing the same for my car but I'm having trouble visualising what I'm aiming for. I'm particularly interested in how you shaped them to be IVA friendly, how big and how rounded they are?
christim
posted on 10/6/24 at 11:04 AM Reply With Quote
Sure here's a pic. If you want the STL file let me know:
My Build Thread
Slimy38
posted on 10/6/24 at 12:21 PM Reply With Quote
Ah perfect, now I know what to aim for. Thanks.
