New Topic New Reply
Author: Subject: Wide bodied 7
Bob Hardy
posted on 18/6/24 at 08:23 AM Reply With Quote
Wide bodied 7
Hi I am researching a 7 build and would like any info on a wider 7 build and any complications it brings??
Slimy38
posted on 18/6/24 at 08:35 AM Reply With Quote
I think the McSorley 442 variation is a reasonably well proven wider option? But you then have the added complication of not many suppliers for bodywork. If you are reasonably confident to make your own panels then it's worth a look.
jacko
posted on 18/6/24 at 12:22 PM Reply With Quote
Not been nosy but do you need a wide body car ?
If you use fiberglass seats it makes a big difference to the size off people fitting in standard 7 s
G
555
PAULD
posted on 18/6/24 at 12:41 PM Reply With Quote
I used a cortina donor and made the chassis four inches wider. Seats were easier to find and an amazing difference in the footwell compared to westfiels and caterhams.
Bob Hardy
posted on 18/6/24 at 02:16 PM Reply With Quote
Wide bodied 7
Will look into this idea cheers
posted on 18/6/24 at 03:55 PM Reply With Quote
You could also make bench seats to get maximum driver & passenger space in the car as well.
See here...
https://www.locostbuilders.co.uk/forum/30/viewthread.php?tid=65698
ianhurley20
posted on 19/6/24 at 09:03 PM Reply With Quote
If you build the later Haynes Roadster you will find it is 4" wider than most 7's & fitted me well - 6' and too many pies 15 stone! Do you need more??
New Topic New Reply
