number-1
posted on 30/6/24 at 09:12 PM |
Drill rpm speed for metal
Can anyone shed some light on the best speed to drill metal? Are low speeds or high speeds better?
I am drilling out a snapped bolt on a 2012 VW Golf with a cordless drill (it holds the diesel injectors in place) but wanted to make sure i dont mess
it up and ruin the drill bit.
Any pointers?
Cheers all
N1
voucht
posted on 1/7/24 at 06:31 AM |
From experience, low speed and a sharp drill bit is what you are looking for.
High speed will overheat and damage the drill bit which will come useless very quickly.
Also, if it is a big diameter, start with a small hole (2-3mm), and drill bigger and bigger.
Hope that will help
https://vouchtroadster.blogspot.com/
https://caferacer-kawa-gpz-zx550.blogspot.com/
JAG
posted on 1/7/24 at 07:08 AM |
You need to know that the 'best' cutting speed varies by metal being cut and the material being used to do the cutting.
This looks like a reasonable guide: Cutting Speed Advice
Justin
adithorp
posted on 1/7/24 at 07:58 AM |
This^^^ Generally it'll be slower than you think.
Plus a good cutting oil helps
http://jpsc.org.uk/forum/
40inches
posted on 1/7/24 at 09:10 AM |
Lots of pressure and low speed Drill a small pilot hole first. 3mm?
If the drill bit squeals it is FUBAR replace immediately.
A good quality cutting paste would be better than fluid if drilling horizontally
MikeR
posted on 1/7/24 at 10:40 AM |
I'm lazy, I've set my pillar drill to the lowest speed and just use that all the time for everything ..........
Tends to be ok.
Controlling speed when you're applying pressure I find very difficult, good luck.
posted on 1/7/24 at 02:12 PM |
I've very often found using a centre punch to mark to spot where you want the drill bill to start helps.
As does starting with a centre drill, before a normal drill bit.
https://www.amazon.co.uk/Youmeng-Centering-60-Degree-Countersink-Metalworking/dp/B09ZTSS8SG/ref=asc_df_B09ZTSS8SG/?tag=googshopuk-21&linkCode=df0&
amp;hvadid=697257156448&hvpos=&hvnetw=g&hvrand=11344433040747448955&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvloc
int=&hvlocphy=9045741&hvtargid=pla-1679688962543&psc=1&mcid=a4ec1c9d57d938de847c60b527750df2&gad_source=1
posted on 1/7/24 at 02:15 PM |
...also, what size is the bolt you need to drill out, M6?
coyoteboy
posted on 1/7/24 at 06:45 PM |
https://play.google.com/store/apps/details?id=com.beta.fswizard_lite
Surprisingly accurate and has rarely let me down.
posted on 1/7/24 at 09:00 PM |
Has the bolt / stud broken above the surface of the cylinder head ? If so my method would to be place a washer over the remains and weld a nut onto
the end of the bolt , the heat from welding and being able to fit a socket/ spanner over the nut and apply slight pressure back and forth will often
shift it. If below the surface try using L/H drill bits which often wind the remains out. Do not use easiouts, the best place for them is the dustbin!
posted on 2/7/24 at 07:23 AM |
Have to agree with "rusty nuts"
Often managed to weld on a nut an the wind out the remains of the sheared bolt. This has got me a few locking wheel bolts off when the key has been
lost.
L/H drill bits are also very useful.
Eaziouts (sp?) are naff and often do more harm than good (and increase the frustration level).
number-1
posted on 9/7/24 at 05:32 PM |
Thanks for the replies chaps. Sorry for the late reply but only just seen the notifications
The bolt was like a stretch bolt that goes through a bracket that then holds down 2 diesel injectors. It was a mates car. Long story short.....we
couldn't get it out and it went to a garage and is now sorted.
However....... I am now in a similar position as i have snapped a 4.5mm chrome vanadium allen key in a grub screw in a Lotus elise rear brembo
caliper!!!!! I bought a new set of Draper drill bits and its not even touching it. This is using a dewalt cordless drill.
Im ordering some cutting agent and considering buying a used bench pillar drill but what drill bits are the best for it? Ive read solid carbide or
cobolt? Any ideas?
N1
tims31
posted on 11/7/24 at 05:33 PM |
For bits like this i'd use a Cobalt drill bit, low and very slow but is just chipsaway at really hard metals. Can be used on Titanium if used
correctly.
I've used on snapped studs before and I use a 1.5mm to drill out holes in nuts and bolts for wirelocking. Light pressure and slow speed 20/30
rpm. Also a good lubricant to keep the heat down, I use some thick engine or gearbox oil.
[Edited on 11/7/24 by tims31]
Build: http://www.martinsfurybuild.co.uk/
posted on 14/7/24 at 05:21 PM |
Agree, slow and lots of torque. I once snapped an easyout in a upright. Tried the usual "fast and lots of smoke" and didn't work. Got a
low rpm 12v cordless hand drill, hot wired it to a car battery and used loads of lube. Quick work.
Mr Whippy
posted on 16/7/24 at 08:23 PM |
Buy a bench grinder (Screwfix sells them for £25) and learn to sharpen your drill bits, it will save you a lot of money...
