posted on 21/7/24 at 04:14 PM |
What counts as normal with locost suspension?
I've bought new shocks, but my wishbone brackets seem small, only 24mm inside. New shocks need 32mm. I foolishly assumed everything was just
standard!
The car is registered as an MK Locost so I've emailed them to check. Fingers crossed I can just get new wishbones and be done with it. Never
liked the idea of 20 year old suspension anyway...
JAG
posted on 21/7/24 at 09:16 PM |
Hello again
I've recently measured the brackets on my car for the same reason - they're 38mm wide with an M12 bolt.
Justin
posted on 21/7/24 at 09:48 PM |
My current bolts look to be 3/8 or 10mm. Which again makes me question if they're not from MK.
Fred W B
posted on 22/7/24 at 10:26 AM |
Could be that the brackets are sized to fit coilovers with spherical joints and not bushed ends. Check if the upper mounts on the chassis are the same
Mr Whippy
posted on 22/7/24 at 11:37 AM |
No such a thing as "standard" on any home built car
posted on 22/7/24 at 12:48 PM |
I'd put money that most people's coilovers have the same sized bushes on the end!
posted on 22/7/24 at 12:52 PM |
Same size both ends. The old coilovers were bushed, but the bottom eye had been welded on in situ. With the bush melted inside!
I could just about stomach having to weld new brackets onto the bones, but the top end would be a nightmare.
jacko
posted on 22/7/24 at 02:13 PM |
You say it’s a mk locost it’s different from the mk Indy as you will already know been you 😀
Mk made locost chassis for Ron champion to start with then went on to build the Indy .
One person that can tell you would be Martin Keenan
In another post you asked about maxi ball joints they where used on Indy’s and locost used cortina four bolt ball joints
I bet you know all this already
Any photos of the car to look at
Graham
[Edited on 22/7/24 by jacko]
555
jacko
posted on 22/7/24 at 02:34 PM |
If you look as google images there are lots of narrow top and bottom dampers some made by Gaz who mk used
555
posted on 23/7/24 at 09:09 AM |
Thanks Jacko. You're quite right there, and the much easier solution is to just get the correct shocks. Cheers!
