Author: Subject: Fuel tank Weight
Dexterdog
posted on 13/8/24 at 11:43 AM Reply With Quote
Fuel tank Weight
Hi everyone,
Westfield megabusa owner
I have been trying to find out the weight (without fuel) of a standard (I believe 27litre) westfield fuel tank.
I am trying to establish if it is worth installing a 4.5 litre tank to save the weight. The car is only used for hill climb.
Does anyone know the likely weight saving ?
jacko
posted on 13/8/24 at 03:20 PM Reply With Quote
If 4.5 is enough fuel to get up the hill + then I would go with that for racing .
If at any time you use it for road then the big tank
Jacko
555
adithorp
posted on 13/8/24 at 05:41 PM Reply With Quote
Probably about 2.5kg
http://jpsc.org.uk/forum/
JimSpencer
posted on 15/8/24 at 07:12 AM Reply With Quote
Hi
Just seen this.. don't know if this will help:-
The main reason we did this (On a Striker, very similar) was so we could move it, from behind the rear axle, to in-front of it, much better weight distribution and much, much safer if you go off backwards.. and you'll remove most of the fuel surge issues you'd probably have (we did!) if your ran a few liters in the big tank
We used a tank (about 7L, small briefcase sized) mounted vertically behind the chassis panel/firewall, but behind the passenger seat (moved forward, and the panel adjusted, a couple of inch) at floor level, but in front of the rear axle, still accessed from the 'boot'.
Mike Wood
posted on 26/8/24 at 11:31 AM Reply With Quote
A smaller foam filled tank might give you piece of mind for fuel delivery compared to using a standard tank with low fuel levels and possible fuel surge/starvation when competing (depending on how quick you go round the bends!).
AH Fabrications and other manufacturers in the UK make a range of different sizes and shaped aluminium motorsport tanks as well as make custom ones to order. See: https://ahfabrications.co/product-category/fuel-systems/ & https://ahfabrications.co/product-category/fuel-systems/fuel-tanks/ (23 tanks)
Mike
[Edited on 26/8/24 by Mike Wood]
