Slimy38
posted on 20/8/24 at 12:04 PM |
Unmodified Escort rack
For a Haynes Roadster, how much of an issue is having the Escort rack unmodified? I think the book says it should be shortened to remove bump steer,
but is that a common practise or is it reasonably safe to leave it as is?
I am using MX5 NA uprights but I believe it's the distance between inner joints that dictates bump steer, rather than the uprights themselves?
westf27
posted on 20/8/24 at 12:19 PM |
As I understand it,with the rack centred.Draw a line through the centre of the top and bottom wishbone mounting bolts.This line ideally needs to pass
through the track rod ball joint.Bump steer is unnerving and can be dangerous depending on when it occurs.Worst situation I incurred was halfway
through a bend at speed and hit a pothole,the car jumped towards the kerb/hedge.Hope that helps
555
posted on 20/8/24 at 02:30 PM |
AS I understand it, the distance between the pivot joints of the inner ends of the track rods should be the same distance apart as the inner pivot
joints of the front lower wishbobones. For the MK Indy, MK narrowed the Sierra rack to achieve this.
[img]
![](/galpreviews/Lower wishbone pivot points.jpg) ![Lower wishbone pivots](/gallery/Lower wishbone pivot points.jpg) Lower wishbone pivots
[/img]
voucht
posted on 20/8/24 at 05:58 PM |
I think a lot of Haynes have been built with unmodified Escort MK1/2 steering rack without any problem.
That is my case and it was fine. With Sierra front upright anyway.
It was not a racing car though.
https://vouchtroadster.blogspot.com/
https://cafrazx550.blogspot.com/
christim
posted on 20/8/24 at 09:14 PM |
Same for me...Having been out a few times now not once have I noticed any bump steer. Unmodified standard MK2 rack and Sierra uprights
My Build Thread
