Author: Subject: Low fuel pressure switch & swirl pot
TimC
posted on 1/10/24 at 02:05 PM Reply With Quote
Hello,
I want to know when my main tank is failing to feed the swirl pot. I do not have provision for, not can easily add any form of fuel level sender. I have a Facet 7-10psi cube pump feeding the swirl pot which houses a Yamaha injection pump.
If I put an adjustable fuel pressure switch (2-7psi) in the yellow-arrowed feed below, will I be able to get the switch to activate if I run low on gas in the main tank?
Fuelsing around
Fuelsing around
My concern is that, because of the free-flowing overflow/return to the main tank, it might not register (enough) pressure.
Obviously, my aim is to not get to this point but I'd like a warning system nonetheless.
Ta,
Tim
adithorp
posted on 1/10/24 at 03:46 PM Reply With Quote
I don't think that'll work. As there's no restriction after the lift pump and fuel is free to flow back to the tank then there's no/little presure in the line... I think...
http://jpsc.org.uk/forum/
TimC
posted on 1/10/24 at 04:49 PM Reply With Quote
That was my fear.
scudderfish
posted on 1/10/24 at 05:42 PM Reply With Quote
Put a restriction in the return line?
jacko
posted on 1/10/24 at 07:05 PM Reply With Quote
Can’t you put a float switch in the side of the tank so it puts a light on the dash
G
555
MikeR
posted on 2/10/24 at 09:07 AM Reply With Quote
Whats the weight of the fluid in the swirl pot? If you have a non return valve prior to the pot and then the pressure switch between the non return and the pot that may work (i'm guessing). eg
Pump -> non return valve -> pressure switch -> Pot full of fuel
