Author: Subject: gas hob v electric hob?
number-1
posted on 1/10/24 at 07:16 PM Reply With Quote
A bit of a random question, but, what hobs do you all use? I have only ever used gas but the missus used electric. I am a bit out of date with energy and what is best so thought id ask on here
I presume electric hob only needs 13a whereas the oven needs 32a?
Reason for asking is i am reviving a small kitchen on a smallish budget
N1
cliftyhanger
posted on 1/10/24 at 08:01 PM Reply With Quote
many single electric ovens run on 13A plug. A normal 4 ring hob will need a 32A breaker and 6mm cable.
Slimy38
posted on 1/10/24 at 08:04 PM Reply With Quote
Cheap electric hobs are horrible (in my humble opinion). Gas hobs are the default 'smallish budget' option, but induction hobs are the best.
A bog standard electric oven from somewhere like Curry's actually come with a fitted 13A plug. Electric hobs do need their own fused spur and induction hobs in particular need very high amps.
SteveWalker
posted on 1/10/24 at 10:35 PM Reply With Quote
Definitely an induction hob - the controllability and rate of change of heating of a gas hob, combined with an easily cleanable flat top.
Schrodinger
posted on 2/10/24 at 07:31 AM Reply With Quote
Bear in mind that for an old codger like me with a Pacemaker in his chest, Induction hobs have to be used with caution as the magnetic field of the hob can wreck the pacemaker, also you need the correct pans fo the hob.
Keith
Aviemore
JMW
posted on 2/10/24 at 08:17 AM Reply With Quote
i.e. magnetic as I understand it. Stainless no good for example. We are just getting a new cooker which has induction hobs so we need to buy a whole new set of pans.
coyoteboy
posted on 2/10/24 at 09:09 AM Reply With Quote
I'm not a fan of induction hobs, they never feel as controllable or as capable as fire and I never find the power varies linearly with the numbers on the dial. But currently have a halogen hob in a rental, and it's the worst thing I've ever used - can't boil a pan because it doesn't stay on 100% even when set to max. It pulses the full output to moderate heat, so stuff just burns, then cools, burns then cools.
Given elec is still 4x gas price per KWh, in a small cheap kitchen I'd go gas.
[Edited on 2/10/2024 by coyoteboy]
posted on 2/10/24 at 09:27 AM Reply With Quote
Always had electric ovens, typically with a 13A connection.
And a gas hob.
Benefit being you can cook on the hob during an electric power cut.
If re-doing the kitchen, SWMBO might prefer an induction hob. Might be a hassle to get the wiring from consumer unit to kitchen, but I'm sure electrician's have ways.
stevebubs
posted on 2/10/24 at 10:23 AM Reply With Quote
Love our induction hob. However it requires a dedicated 32A supply.
There are induction hobs that will work on 13A plugs but they're limited in power and you lose the ability to get heat into things quickly so (IMO) I'd rather have a gas hob than a limited power induction.
Sylva Fury
stevebubs
posted on 2/10/24 at 10:24 AM Reply With Quote
Just an FYI, I used these when putting my ovens in - made the installation much easier...
https://www.screwfix.com/p/greenbrook-20a-3-way-lever-lighting-connector-with-quick-click-push-fit-terminals/326PG?gclsrc=aw.ds&gad_source=1&g clid=EAIaIQobChMIn7yWl73viAMVTJNQBh26sAxZEAQYAiABEgL5lPD_BwE&gclsrc=aw.ds
Sylva Fury
stevebubs
posted on 2/10/24 at 10:25 AM Reply With Quote
My Bosch induction hob is fantastic....real easy to turn up/down. Don't regret it one iota.
Sylva Fury
gremlin1234
posted on 2/10/24 at 12:44 PM Reply With Quote
most gas hobs plug in the electricity for the ignition spark, during a power cut you have to light it with a match.
gremlin1234
posted on 2/10/24 at 12:47 PM Reply With Quote
I think it just disables the pacemaker while too close, and not wreck them completely. but yes best avoided
gremlin1234
posted on 2/10/24 at 12:51 PM Reply With Quote
Originally posted by stevebubs
There are induction hobs that will work on 13A plugs but they're limited in power .
limited to total 3kw, so for a twin hob 1x2kw, + 1x1kw. or just a single 3kw hob
posted on 2/10/24 at 01:02 PM Reply With Quote
Agreed, our gas hobs have electric sparks to get them going, but a match does just as well.
adam1985
posted on 2/10/24 at 03:43 PM Reply With Quote
Had a induction hob for a few years now and it’s brilliant, only thing I don’t like about it is the touch controls they can be a little temperamental especially if they are damp from cleaning the hob
SteveWalker
posted on 2/10/24 at 06:43 PM Reply With Quote
Some need electricity for flame failure detection, to cut-off the gas if you turn it too low and it gets blown out. Without power, you cannot light them at all.
posted on 2/10/24 at 09:35 PM Reply With Quote
Just to add, some new induction hobs can be programmed to not use more than 13a. Most of the time you won't notice the difference, it just alternates which ones are active. I personally use an old electric hob, took it out of someone's kitchen 7 years ago and put it in mine. Still works mint!
russbost
posted on 3/10/24 at 08:17 AM Reply With Quote
We have an induction hob & yes, they are great. However in terms of cost a gas hob has to be way cheaper, no "specific" pans, uses slightly more kW power, but at around 7p a unit rather than around 4 times that. As long as you have gas already there, then far cheaper to install & they require virtually no maintenance & last forever!
number-1
posted on 8/10/24 at 12:12 PM Reply With Quote
Thanks for all the replies. Some very interesting points raised.
I ended up going for a gas hob for ease as there is already gas behind the unit.
N1
posted on 11/10/24 at 08:45 AM Reply With Quote
N1
That was a big deciding factor for me was ease of install (still have to get a Gas Safe person, but the gas is there) and cost.
I've fitted my own kitchens around working and got people in to do the bits I can't (Gas Safe).
