Author: Subject: Another adhesives question
Slimy38
posted on 18/10/24 at 08:25 AM Reply With Quote
I'm doing a bit of shopping on car build solutions and happened upon this;
https://www.carbuilder.com/products/weld-in-2-18tpi-threaded-filler-neck
It talks about welding or bonding on to a tube. This got me thinking, what could be used to bond something that is exposed to fuel? Are polyurethane glues like Tigerseal safe for fuel?
posted on 18/10/24 at 08:48 AM Reply With Quote
1. Probably my welding's not good enough, but I'd be worried about heat distorting threaded section.
2. Bonding I'd be worried about the fuel (liquid and vapour) and the mechanical strength.
On my fuel tank filler I had a similar looking part with a longer plain section. I used fuel filler hose and fuel hose clamps to secure it to neck of the tank.
Slimy38
posted on 18/10/24 at 08:58 AM Reply With Quote
Hmm, a longer version would make sense. The challenge I have is panel mounting it, but if it's longer then the panel mount collar wouldn't be in contact with fuel and I could use Tigerseal without issues. I appreciate the response, it's got me thinking about other options.
russbost
posted on 18/10/24 at 09:03 AM Reply With Quote
Any good PU adhesive is fuel resistant, just check on manufacturers specs. Siroflex that we always used certainly was
MikeR
posted on 18/10/24 at 12:01 PM Reply With Quote
Assuming the aluminium tube goes inside the threaded section, thats a massive area that would be bonded and it wouldn't really have any/much fuel touching it. As long as the glue is fuel save i can't imagine their being an issue.
jacko
posted on 18/10/24 at 12:51 PM Reply With Quote
This has surprises me I am sure you are right
but after 30 + years working on bus body’s I car say diesel definitely doesn’t work well with pu glues it breaks the glue and makes a mess
G
555
MikeR
posted on 18/10/24 at 02:52 PM Reply With Quote
Not the same, but petrol attacks silicone. It turns into "gorilla snot"
(I got that from this forum years ago and still remember it)
russbost
posted on 18/10/24 at 05:48 PM Reply With Quote
G
Never used it, but here's a PU that's diesel resistant
linky
jacko
posted on 19/10/24 at 12:57 PM Reply With Quote
Russ
That’s a new one to me I will have to remember that for future use
Thankyou for the info
Graham
555
