Author: Subject: Zetec Cooling
Schrodinger
posted on 21/10/24 at 02:08 PM Reply With Quote
Zetec Cooling
I have a 1.8 silvertop zetec in my Stylus and I am using the standard ford thermostat housing. The housing has a bypass which I know needs to be plumbed into the bottom hose between the rad and water pump, but does the other connection for the heater need to be connected as well or can I just block it off as I do not need a heater. (electric heated screen, for info)
Keith
Aviemore
gremlin1234
posted on 21/10/24 at 04:10 PM Reply With Quote
the logical answer is, No you don't need it connected, since if you had a heater, and turned it off, there would be no circulation there.
Schrodinger
posted on 21/10/24 at 05:45 PM Reply With Quote
that was the way my logic was taking me, but I'm sure I had seen somewhere that you should not do this and I can't remember why.
Keith
Aviemore
gremlin1234
posted on 21/10/24 at 07:12 PM Reply With Quote
it might be that it gives a 'blead' point, so you can remove air / air locks from the system
Schrodinger
posted on 23/10/24 at 08:46 AM Reply With Quote
Thanks for your thoughts.
Keith
Aviemore
