Author: Subject: Fuel filler neck
Slimy38
posted on 28/10/24 at 12:53 PM Reply With Quote
Fuel filler neck
I'm reaching out to the masses for a bit of help sourcing a part. I'm after a fuel filler neck, similar to this;
eBay Item
But with a 40mm internal, 55mm external diameter. I can see 60mm and upwards, but not smaller. Is there some dark mysterious part of 'the internet' where such a neck can be sourced?
I've actually 3D printed one and it works really well, but I have no idea how I could prove to the IVA inspector that it would be safe. And I'm not convinced 3D prints are considered leak-proof.
jacko
posted on 28/10/24 at 01:17 PM Reply With Quote
EBay link does not show a filler
555
Slimy38
posted on 28/10/24 at 01:28 PM Reply With Quote
Oops!! Try this direct link;
https://www.ebay.co.uk/itm/264987377628
Slimy38
posted on 28/10/24 at 02:28 PM Reply With Quote
eBay Item
Ignore that last comment, while PETG appears to be able to hold water it's unable to hold any solvent, so it's not an option for this task. I could start venturing into sealing it with epoxy or similar coating, but it looks like I'm back to finding a regular old metal one.
MalP
posted on 30/10/24 at 07:12 AM Reply With Quote
Fuel Filler
A log time ago I bought a filler neck along the lines that you want from
Compbrake.com which I was satisfied with.
HTH
Mal
