Author: Subject: Engine number for an IVA test
mgb281
posted on 1/1/25 at 07:29 PM Reply With Quote
I am fitting a Jaguar AJV6 engine in a MGB, due to the modifications to the bulkhead and a coil spring rear axle among the most noticeable mods I am sure it will need an IVA test. Amongst a few other problems is the engine number, Ford in their wisdom never stamped an engine number on the block, or anywhere else come to that. All they used was a printed sticker on the front of the engine, when I gently wiped twenty years of grime off the sticker the serial number was wiped as well. Will I have a problem at the IVA test? What have others done?
Obviously I have tried my local Jaguar dealer a very helpful man said that as Ford built the engines Ford kept the build details and since Ford sold Jaguar they no longer have access to any info. All they were able to produce was a car build date in March 2001 and a registration date of 2001. Any guidance would be appreciated.
cliftyhanger
posted on 2/1/25 at 09:14 AM Reply With Quote
The change to rear suspension is only 2 points lost, so isn't an issue. The bulkhead, on a monocoque, might be.
Depending on if you have "repaired" the area or done something obviously drastic. I know any alterations to the monocoque should result in IVA, but lets be honest, if it looks "factory" and is done well......
Regarding engine number, I have created my own unique number for a zetec where the etched number was unreadable. In fact I used the zetec engine code (I think it was NGA) and stuck that on the end of the Triumph engine number I was removing. That idea came from seeing factory recon engines wherer they had added a suffix to engine numbers.
mgb281
posted on 2/1/25 at 09:39 AM Reply With Quote
I didn't fully detail the changes, in addition to the welded in coil spring mounts, there is the bulkhead mods, different gearbox, the holes in the inner wings for the exhausts to exit and the steel welded on wheel arch flares, modified front cross member for engine clearance, the EPAS and an additional UJ in the steering to lower the shaft to clear the manifold Some of these I could argue MG did ie similar bulkhead mods for the V8 engine and the inner arch holes for the exhaust. A previous owner put two new rear half wings on but he made such a hash of it there was really only two options, either two new full wings (£825 each) or the arches to cover up 90% of the damage. I am not sure if some of them count, ie the EPAS, the brake upgrades front and rear, Sebring fibre glass flares seem to be OK but steel ones? I plane to visit a local IVA test centre to see if they can clarify things.
adithorp
posted on 2/1/25 at 01:45 PM Reply With Quote
None of which would need notifying IMO (assuming you're 1/2 competent).
http://jpsc.org.uk/forum/
adithorp
posted on 2/1/25 at 01:46 PM Reply With Quote
mgb281
posted on 2/1/25 at 03:00 PM Reply With Quote
I have found the answer here; https://www.jaguarforum.com/threads/engine-number-location.110630/
gremlin1234
posted on 2/1/25 at 06:25 PM Reply With Quote
there are quite a lot of 6 cylinder engines with the engine no. 1-5-3-6-2-4. (mistakenly taking the firing order :-)
mgb281
posted on 2/1/25 at 07:30 PM Reply With Quote
Yes especially only the first six numbers are required for the engine id.
pewe
posted on 6/1/25 at 10:52 AM Reply With Quote
When I registered my kitcar I invented both chassis and engine numbers (both legit items), stamped up plates using dies and welded them in visible locations.
Theses were accepted without question - format matched equivalent items.
40inches
posted on 6/1/25 at 11:08 AM Reply With Quote
The engine number is below the nearside engine mount.
mgb281
posted on 6/1/25 at 11:16 AM Reply With Quote
Thank you for that, I had found it but that will be very helpful for others. The local Jaguar dealer had no idea where bit was.
How did you get you engine so clean? Although I I only spent five minutes with a wire brush in an electric drill I didn’t clean up much of an area and certainly nowhere near as good as your block. Did you media blast it?
40inches
posted on 6/1/25 at 12:25 PM Reply With Quote
Clean and rinse with an engine cleaner, rotary wire brush in drill and 1 coat of Halfords silver engine paint
Still looks like that 10 years later.
mgb281
posted on 20/1/25 at 06:40 PM Reply With Quote
Well you could be correct, today being too cold to work on the MG I drove down to the Exeter IVA test centre and detailed what I had done and the tester told me to fill out the new engine number and capacity and send the V5 to the DVLA. He said that the DVLA will just alter the V5 and send it back or pass it onto the DVSA who will either ask for photos of what has been done or will demand an IVA. He said it all depends who amends the V5 as to whether they inform the DVSA. He has a friend who bolted (welded?) a Volvo XC 90 bodyshell onto a discovery chassis, there were lots of chassis mods but it went straight through as a LR Discovery.
